I have a '77 f-150. It has a Lincoln 460 in it. The radiator was leaking on the bottom. I replaced it. When I took the transmission lines off the old radiator nothing came out. Is that a problem? Is it from the radiator being bad?
Not yet. I am a truck driver. I will be home next weekend. I was just wondering what I needed to look for and worry about.
The bottom part of the radiator that the transmission lines go into/out of is just a stock transmission cooler, the fluid goes in, cools down, and returns back to the tranny. Not getting anything out of those lines would almost definitely mean you are low on fluid. Hopefully the cooler part of the rad. didn't have any sort of crack in it where you lost fluid...
