fender spacing 56
Old Oct 15, 2011 | 06:16 PM
pedalman's Avatar
pedalman
Cool fender spacing 56
hi guys I have put the frontend togethere the hood is fitting fine, but the fenders is where I am haveing a little trouble they are all bolted up to the cab and the core support the best I can get them, but at the front I have about 3/8" space on both sides and the backthey are touching the hood.
can anybody tell me what to do to get it more of an even space .
Thanks
Also what is the best way to check if the cab is square to the frame.
Old Oct 15, 2011 | 07:59 PM
cmoritz's Avatar
cmoritz
Did you install the rubber beaded strip between the cab and fenders?? ..that could help that area a little, in the front, sounds like you have some more adjusting to do..might consider moving both air deflectors inbd.
Does the hood latch? good fit at the cowl? ..front of fenders and hood line up ok?tough to tell without pictures, but maybe the fenders need to be loosened across the inner fenders and then the deflectors pulled in...then try re-mounting the radiator strip and see how it works. I know it takes alot of time..but the more time you contribute to it...the better it looks. Good Luck!
clintonvillian
Nov 9, 2018 09:18 PM
zoomeroo
Feb 7, 2011 12:26 PM
kaw500h1
May 27, 2005 03:55 PM
muddog899
Nov 17, 2004 11:08 PM
rchassie
Paint & Bodywork
Mar 18, 2003 04:33 PM
