I bought my excursion about a month ago. I recently started looking for the block heater plug just to get things ready for winter and I can't seem to find it. Is there a specific place where the plugs are hidden? Do all of these 7.3 come with plugs?
Reach in the bumper by the drivers side foglight/tow hook area. They are tucked in there hidden. It may still be secured to the harness if it has not been used previously.
Here is the location.
Reason: added pic for future
I have been reading all over the internet and have a question. I have a 2002 Ford F-250 Lariat 7.3L and cannot locate the cord at all. I have looked for at least an hour. I do see the orange cable/wire coming off the oil filter housing like the picture above but cannot track down the plug. If i buy a plug from ebay or where ever, will it plug into the housing that maevens posted above and replace that wire? Should I buy the whole heater assembly?
Take that Orange cord and fallow it to the front you will find the plug. I would not spend the money on a new one since you already have one on the truck.
I got it jacked up and chased the wire from the oil filter housing all the way to the front drivers frame rail where it goes over the top and down to the two fog lamps. There is a 1-2 ft loop that has not plug and goes back the same way in which it came. No plug from Ford for some reason. The question I have now is when I buy a new cord to replace this will leaving the OE cable in tact, because God knows where it goes cause any issues?
So if I unplug my wire harness coming out of the warmer, will there be any issue to just tie it up and install the new cord?
that cord from Oreilly does not look like the same one in the picture from post #5???
Did you find the End of the cord that comes out of the 'block' heater. It should have an 'end' to it and a electrical plug on the end of it. Find the 'End' and install a plug on it if it has no plug. By saying that it is going back the same way that it came out (from the loop) find where it goes and you will the a loose end......
The cord can be purchased separately and plugged into the heater you already have. You can order one from any truck dealer by asking for a phillips & temro (zerostart) cord #3600008
