Drive shaft position
Old Oct 17, 2011 | 02:59 PM
salf100's Avatar
salf100
In a stock 64 F100 2wd with 3 spd trans, is the drive shaft position straight back to the third member? When you look at the drive shaft from the back of the truck, is it off to one side or perfectly parallel to the frame rails? Mine whole differential is slightly to the right (passenger side).
Old Oct 17, 2011 | 06:44 PM
DPhillips's Avatar
DPhillips
Typically, Fords have the engine offset about 2 inches to the passenger side of the engine bay. The diff is offset likewise. If the engine was swapped, whoever did it might not have been aware of this.
Old Oct 17, 2011 | 08:42 PM
salf100's Avatar
salf100
Ok, it has the stock motor and trans. I removed the diff. and just was scratching my head when I put it all back together!
76EconolineND
Aug 8, 2009 12:30 AM
F100DREAM
Sep 22, 2003 06:28 PM
alecams
Nov 5, 2002 01:23 AM
abe1217
Oct 12, 2002 11:07 PM
