E-350 van cold starting issues
Old Oct 15, 2011 | 08:56 AM
sailorjohn's Avatar
sailorjohn
First off - Yes - I have read all the sticky threads and searched for the info I'm looking for.
I've had my E-350 7.3L PSD for about 3 years and each year the cold starting problem gets worse. At first all I needed to do was change the week battery but last year I changed out both batteries for a matched set and still had some problems. I was going to work on it this summer but never got around to it. Now that the weather is getting cooler I need to get this problem fixed.
My first problem is that I don't know if I have a GPR or a GPCM. My van manule doesn't cover deisels. I have opened the rear cover and removed the heat shealds and air filterbox but I don't see any relays.
Is there any where that I can get step by step info on how to find/test/replace my GPR/GPCM and test/replace my glow plugs - ON A VAN???
Old Oct 15, 2011 | 02:24 PM
duck fan's Avatar
duck fan
Because racetruck
Can you describe your cold starting problem for us?
Old Oct 15, 2011 | 02:38 PM
sailorjohn's Avatar
sailorjohn
engine turns over but does not start. Some times it will start on second third or fourth try. Sometimes the batteries run down before it gets started and it wont crank any more. Useualy when this happens it will start with a jump on the second or third try.
I removed the alternator and saw the two relays behind it. Looks like I have a GPR. The second relay (furtest towards the back) looks newwer than the other. However, it is still not possible for me to get any test equipment on it.
Old Oct 15, 2011 | 02:52 PM
duck fan's Avatar
duck fan
Because racetruck
In a van unfortunately its really hard to get in there. The only test equipment you need is a good multimeter.
Old Oct 15, 2011 | 03:43 PM
sailorjohn's Avatar
sailorjohn
Do I need both batteries hooked up or will one suffice?
Old Oct 15, 2011 | 04:43 PM
Krazymaan's Avatar
Krazymaan
John, I am a van man. you do have a relay. if your looking through the hood, its on the left about 10" back from the front of the valve cover. You will have better access to it if you remove that big block of wires right there in your face. With a 10mm. Unfortunately its the one further back. there looks like two in a row but its the furthest one back. If you don't want to play the make another one fit somehow game. Just get a new one from ford. its not too much money. It will fit correct and the bent wires will hook up correctly. sometimes playing games just ain't worth it. Because as you know, under a van its very hard to alter things when you cant reach.
But i replaced my glow plugs and had the thing plugged in and it went like this. turn the key and leave it forward for 30 seconds or so. turn off ignition. turn key on and wait for 30 seconds again and it seems like the van only wants to pop off during the first second or two anything after that just forget about it. turn the key off turn it on and the second the light goes off quick try to start it. Its like you have to catch it in the right sequence for it to start. Well, i changed my GPR and it was like a whole new engine as far as starting was concerned. Plus you should have a normal GPR and not that digital box thing. The digital box thing is for california smog vans. I already went through all this. So take my advice and get a GPR, put it in and move on. You'll be happy. Unless you have a few bad glow plugs then thats a different strory.
Old Oct 17, 2011 | 06:06 AM
sailorjohn's Avatar
sailorjohn
Thank you Krazy,
I see the "big block" of wires and the GPR.
What is the first (forward) relay for?
If I remove the first relay to get access to the GPR will I beable to accuratly test the GPR?
Old Oct 18, 2011 | 03:22 PM
sailorjohn's Avatar
sailorjohn
BUMP
If I remove the first relay to get access to the GPR will I be able to accuratly test the GPR?
Anyone?
Old Oct 18, 2011 | 05:51 PM
Krazymaan's Avatar
Krazymaan
i cant remember what the first solenoid is for anymore. but i didn't remove the first one to remove my gpr. I just stuck the 8 or 10 mm socket down there and undid the two bolts and it was free. But i did undo all the other wires on top first out of common sense.
If you get a new gpr just don't install it backwards because it will blow fuel into your air filter and ignite. You don't want that happening. Yeah, Im just kidding. but seriously make sure you watch those little wires and immediately look for the - and + so you don't put the wires on the wrong side. write it down or something, your short term memory is shorter than you think.
Personally i wouldn't waste my time testing the gpr. first off, you can't open it and see how much damage is done to the disc inside even if your tool says it has good ohms or volts it doesn't tell you if the mechanical parts are good. Its a cheap fix that these trucks need anyways.
Old Oct 19, 2011 | 12:18 AM
duck fan's Avatar
duck fan
Because racetruck
The front one is the AIH relay. As long as the batteries are disconnected, you can remove it. But I'm with Krazymann, just replace it. Not too hard and if it isn't bad now, it will be eventually.
IDIDieselJohn
30
Nov 28, 2013 09:54 AM
sailorjohn
Oct 27, 2011 07:39 AM
peboiteau
61
Apr 13, 2009 10:56 PM
jayc3169
Nov 23, 2008 04:47 PM
AerostarDad
Aerostar
Aug 9, 2005 10:15 AM
