going with auto, which ranny
Old Oct 14, 2011 | 11:43 PM
redsvt's Avatar
redsvt
i have a 77 f100 witha 351m 4spd 2wd, and i want to go with c6 tranny, but i dont know much about this trucks so any advice, i want something that is strong and fast, i will rebuilt the transmission before install, and i might rebuilt my engine or install a 460 later. Also what stall to go with and shift kit. Thanks
Old Oct 15, 2011 | 06:11 AM
miottimouse's Avatar
miottimouse
c6 with a shift kit will work well for you but going from a manual to a auto you probebly will need the cross member and a speedo cable as well also a rad with the cooler or an aftermarket set up personaly i would stay away from the "stall converters" as they generate too much heat for normal every day driveing my 78 with 501 cid/500hp/c6 w gearvenders overdrive works just fine off the line with the stock converter
Old Oct 16, 2011 | 10:47 PM
redsvt's Avatar
redsvt
wich cars or trucks have the c6?
Old Oct 17, 2011 | 04:43 AM
miottimouse
most pickups 79/79 should fit your engine 351/400m 460 just make sure you get the ring gear and converter you will also need a auto trans steering columm or a floor shifter of some type i would look for a 351/400 m parts truck that way you have every thing you need
tlrtucker
Mar 7, 2016 07:15 PM
Dflynn926
Jun 13, 2014 02:41 PM
Colo. Motor Head
Jan 28, 2010 12:43 PM
Ratsmoker
Jun 2, 2002 03:00 PM
