Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Diagnostics
- Why is My Truck Losing Power?
Guide to Diagnose trouble and recommended solutions
Loss of power with my 7.3l, rough running HELP!
I have a 2001 ford 7.3l powerstroke diesel. When I first noticed the problem I was towing a trailer going up a grade and got into the throttle almost to the floor and noticed a loss of power and the service engine soon light flashing extremely rapidly a few times and never came back on. I made it home, still lacking power but not running rough. I drove the truck to work the next day and the truck was running rougher and loosing power. It ran great through lower RPM's but seemed to trip as soon as you gave it over half throttle. eventually the truck wouldn't run right at all and lacked complete power. It idled rough as well. My mechanic threw the computer on it and it said injector pressure reading too high or too low. I was told to replace the IPR on the HPOP and I did. (I also replaced the fuel filter and changed the oil). After replacing the IPR it ran great, had full power! then it began to slowly die like it did before until it sounded like it was running off 4 cylinders again. I pulled the ipr out, cleaned it and changed the oil again. It seemed to clear it up for an hour and ran great but then began ran rough again. I also replaced the CPS sensor. I feel like its not getting enough fuel or something, im just wondering if it could be the ICP or the lift pump. oh and there is no check engine light at all. Its just got me stumped because cleaning the IPR clears everything up.... temporarily.
Based on what you mentioned, I'd suspect the injector o-rings.
By any chance did you send your used oil to get analyzed? If so, was there any fuel in the oil?
Was your old fuel filter black when you pulled it out?
Another potential culprit could be a restriction in the tank OR a stuck Fuel Pressure Regulator. Both of those items can throw ICP codes. When you drained the fuel to change the filter...did you get about 16oz out or a lot less? Did the fuel spit out of the train tube? Almost like it was under a lot of pressure and had a bunch of air in it?
Have some safety glasses on just in case the fuel comes out quicker than you expect.
Low fuel flow will freak out the PCM and it will throw ICP codes while it fights to keep the engine running so we should make sure your fuel system is up to par before changing any other parts.
Sounds like you found your problem. Time to drop the fuel tank and clean the screens or perform the in tank mode. Like Jim said...search for Guzzle Hutch mod and you should come across a nice write up.
Since you were new, you may not know who Guzzle is, here is a direct link to the hutch/harpoon modifications Welcome to guzzle's In-tank Hutch Mod Web Page You do not necessarily have to add the large filter/prepump setup, you could just do an inline NAPA filter PN 30007
this sounds just like me please help
hi im new here but thissounds just like me ! can u please tell me where i should start and what u have found to be the problem? i really dont have the time or money to go through my truck the way it sounds u have. Anything thing will help thank u in advance!
