help with over charging problem
Old Oct 14, 2011 | 09:09 AM
TNT in Round Rock's Avatar
TNT in Round Rock
first off - howdy guys. Haven't been on much - havent really been modding much or having problems.
So let me preface this by saying this truck has dual 110 amp alternators. Had to replace the batteries recently, and I'd just turned 200,000 miles so it was time to check. Both alternators failed on the bench so I replaced them both.
I have an aftermarket volt meter in my gauges as well, and it was starting to jump up into the red (14+) volts in the morning. It only did it intermittently. After a week or so, it was getting worse, so I swapped the alternator.
Fast forward a month, it started doing it again. This time it PEGGED the aftermarket and OEM volt meters. One early morning it did it so bad it blew out all my headlights !!!!
I took the top alt back in and it failed the test, so I replaced it again.
This morning while driving home, I noticed it jumping up a little bit again into the "yellow" area on my voltmeter showing a slight overcharge. This is a brand new alternator, brand new batteries.
Is there something else in control of the voltage / output that could be failing ????
Old Oct 14, 2011 | 09:35 AM
nlemerise's Avatar
nlemerise
I once had a car which exhibited the same problem...changed the dang alternator and burned up a battery due to it. Did the same thing again, but this time I started looking for another problem (other than the alternator & battery). It turned out to be a bad ground between the body and battery. I can't believe you would have found four alternators with bad voltage regulators...
Old Oct 14, 2011 | 10:18 AM
HH60FE's Avatar
HH60FE
My thoughts too, ground(s)
Old Oct 23, 2011 | 09:02 AM
TNT in Round Rock
I've checked the grounds .. they're as tight as possible.
What else could it be. Now what I have noticed is this is only in the morning after it's sat overnight, and with my headlights on. Later on in the day there's no problem ... I'm beating my head on the wall with this one...
Old Oct 23, 2011 | 02:58 PM
Bonanza35's Avatar
Bonanza35
Subcribing.
I would take it to an alternator shop and have them check the system and tell them the history. Stay and watch. Chet
Old Oct 23, 2011 | 04:36 PM
bfife's Avatar
bfife
still plays with trucks
Tight doesn't mean its good. Run a 6 or 8 guage ground wire from the alt mount up to the batt Neg.
Barney
Farmboy1539
Jul 31, 2015 01:13 PM
sprint406
37
Feb 21, 2012 06:25 PM
Skrilla
18
Jan 23, 2010 01:16 PM
ford03_iw
Jan 19, 2005 10:44 AM
No_BS
Nov 10, 2004 10:41 AM
