TSB #17738 fix???
Old Oct 14, 2011 | 08:07 AM
TheQuakerMan's Avatar
TheQuakerMan
TSB #17738 fix???
I have done hours of looking and can't find anything actually showing/telling you how to fix this TSB without paying for something that may or may NOT help. Anybody?
Old Oct 14, 2011 | 03:26 PM
alloro's Avatar
alloro
Yeah okay, and you didn't think it would help get you some answers if you bothered to post the text of the TSB or a link to it?
Old Oct 14, 2011 | 05:42 PM
projectSHO89's Avatar
projectSHO89
Ford's TSB numbering system doesn't look anything like that...
Old Oct 17, 2011 | 07:10 AM
TheQuakerMan
2003 FORD EXPEDITION: 17738 10008238 20040401 110000 ELECTRICAL SYSTEM
TSB data for: 2003 FORD EXPEDITION
Bulletin Number: 17738
Sequence Number: 10008238
Date: 20040401
Component Name: 110000 ELECTRICAL SYSTEM
Make: FORD
Model: EXPEDITION
Year: 2003
Summary:
CHARGING SYSTEM WARNING INDICATOR INTERMITTENTLY ON WITH POSSIBLE DIAGNOSTIC TROUBLE CODE (DTC) P0620. *TT
Old Oct 17, 2011 | 07:12 AM
TheQuakerMan
here's the link...
2003 FORD EXPEDITION TSB's (technical service bulletins)
Old Oct 17, 2011 | 09:52 AM
alloro's Avatar
alloro
Are you getting a P0620 trouble code when you scan the vehicle, or are you looking into this TSB simply because the dash charge light is coming on intermittently?
Old Oct 17, 2011 | 10:01 AM
TheQuakerMan
Because of the intermittent charging light, I don't have an OBD scanner to use. I'm just wanting to try a few things, so I figured being that I'm not the only one with this problem I should try to see if my problem is the one the TSB is referring to. I've checked my voltage from my alt, had my alt load tested etc. and none of those helped with diagnosis. I was to the point where I was going to just assume this was a "GREMLIN" and tolerate it.
Old Oct 17, 2011 | 06:39 PM
projectSHO89
You need TSB 04-14-9 which is not available through this site.
Old Oct 17, 2011 | 07:09 PM
R&T Babich's Avatar
R&T Babich
Did you check the wiring harness from the alternator to see if it is rubbing anywhere and subsequently worn through the insulation?
I've seen an alternator harness rubbing on an A/C line wear through the insulation, short out to an aluminum A/C tube, melt the tube and release the coolant.
Old Oct 17, 2011 | 07:15 PM
alloro's Avatar
alloro
In that case your serpentine belt could be worn and slipping, the belt tensioner could be weak allowing the serpentine belt to slip, or if the battery is old the intermittent flashing can happen.
Old Oct 18, 2011 | 04:21 AM
broncoholic's Avatar
broncoholic
I found this on mine when I changed my alternator. Hadn't rubbed all the way through yet, thankfully. I split a vacuum hose and taped it around the wire.
Old Oct 19, 2011 | 11:17 AM
TheQuakerMan
Thumbs up Check charging system flickering...I think it's gone.
I found that! On the A/C line that runs next to the battery I had some carbon build up from slight arcing to the aluminium line. I wrapped it in insulating tape and haven't heard one beep or seen the light flash once yet. It hadn't damaged the A/C line either.
tmc4242
Mar 12, 2010 02:30 PM
jdm5630
Feb 25, 2010 04:35 PM
Ractor
Sep 14, 2008 07:23 AM
00RedExpedition
Oct 14, 2004 10:23 AM
LarryInPa
Feb 10, 2004 01:00 PM
