I'm missing a rear brake drum off a 57 f600 I just got, it has a two speed rear in it. Does anyone know where I can find one or what other year drums will fit.
Did you see if there's a build tag on the rear of the axle? Probably an eaton if its a 2 speed. Places like Truck-Pro will want that info if they can even come close. Where you from? I've got a complete rockwell rear that will fit an f600, but its only a single speed. It also has 700 original miles on it. I was going to put it in my f350, but it more work than I want to deal with.
i think there might be more than 1 size , width , diameter ! if you can pull the other side off then you will have some thing to measure , and get a duplicate !
I'm going to try to get down to the truck this week to look for the number on the drum, I had these pics already and figured it wouldn't hurt to post them.
I'm not going to have time to pull the drum to get a number this week, but I did measure the brake shoe on the other side and it is 4" wide.
Do you also need the hub? It does not come with the drum.
B6Q-1126-C .. Rear Brake Drum-Use with 15" x 4.00" & 15" x 4.50" brake shoes / Obsolete
Applications: 1956 B700/750 with Tandem Axles (T/A) / 1957/62 F500/600 without T/A.
JST AUTOMOTIVE in Lebanon TN has TWO = 615-443-3086.
--------------------------------------------------------- B6Q-1109-B .. Rear Hub-Same applications as the drum / Obsolete
I was unable to locate any on the two online parts locator sites, try Job Lot (joblotauto.com) in Queens NY (not on the locators).
