1996 F-350 4x4 shift problems
Old Oct 14, 2011 | 01:15 AM
dstanford's Avatar
dstanford
yesterday this truck was working fine,but this morning they came back to the yard and said that the truck was shifting crazy,it would shift up then down,and the shift's were hard shift's,and the speed-o-meter quit working at the same time,I know it has some thing to do with the way it's shifting, but the odometer does't even have any numbers showing,its like there isn't any power to it,what I would like to know is there a relay or module that controls the speed-o-meter,I know the cruse control is tied up it in but this is a 7.3 DI diesel and the cruse control must be built in the system,this transmission was rebuilt last summer and it hasn't had a problem,but trying to talk to the shop is ,well they wont talk on the phone, has any one dealt with this before ?
Old Oct 14, 2011 | 08:53 AM
craftsmangary's Avatar
craftsmangary
Your speedometer problem is causing your trans problem. A common failure is the "PSOM" programmable speedometer odometer module, search on that, basically you probably need a new speedometer. Also the VSS, vehicle speed sensor.
Old Oct 14, 2011 | 10:44 AM
madpogue's Avatar
madpogue
*** Duplicate thread *** See https://www.ford-trucks.com/forums/1...t-eriadic.html . Let's pick up the conversation there, since there are already more replies on that thread.
Old Oct 14, 2011 | 11:34 AM
dstanford's Avatar
dstanford
do you mean the gauge it's self,I changed the sensor on the rear end over the third member but if there's another one somewhere where is it located,thank you
Old Oct 14, 2011 | 11:39 AM
dstanford's Avatar
dstanford
thank you,but I pulled the gauges out and checked all three plugs and there all good and the wiring is not corroded or damaged and the pink with orange wire has 3.3 volts in it
Pete Hamstra
May 25, 2019 02:31 AM
Shanemh
Mar 17, 2012 05:47 PM
dstanford
22
Oct 14, 2011 08:45 PM
handyman43358
May 6, 2006 09:00 AM
jimmick
Aerostar
Jun 11, 2003 06:10 PM
