hp estimate
Old Oct 12, 2011 | 09:20 PM
smoke n tires's Avatar
smoke n tires
hp estimate
i was hoping for some estimates on hp from a 302 i recently swapped into my 68 f100. its .030 over with speedpro pistons, 9.5 to 1, E7 heads port matched with heavy exhaust port work, comp 224-230, .509-.512 cam, shorty headers w/ 2.5in dual exhaust, 600cfm holley, offy port o sonic single plane intake, stock bottom end. the motor seems to run very well in this old truck. i was guessing around 300hp and 325ftlbs.....
Old Oct 14, 2011 | 05:04 PM
Conanski's Avatar
Conanski
Yeah 300hp at the crank isn't a bad guess, E7 heads as cast are only good for about 275hp but there is surprising potential in them. In a recent thread I saw on one of the Mustang forums a guy managed about 400 crank HP with them but only after he spent something like 200hrs porting, obviously he really knew what he was doing.
Old Oct 14, 2011 | 09:39 PM
79superduty's Avatar
79superduty
do u have flow numbers for the port job ?
Old Oct 15, 2011 | 09:06 AM
Conanski's Avatar
Conanski
I looked and can't find the thread at the moment, but if I remember correctly it was right up there with what an AFR165 does.
Old Oct 15, 2011 | 07:21 PM
79superduty
well the dyno sais alittle more you should about 350 or so .
Old Oct 16, 2011 | 10:45 AM
smoke n tires
i dont have any numbers on the flow but i spend alot of time on the exhaust side removing the bump and matching the gaskets. the intake side isnt as bad, just matched the inlet to the gasket.
87Mater
Jan 25, 2009 03:42 AM
umdstang
Apr 28, 2005 04:58 AM
Need4Speed
Jun 29, 2004 08:17 PM
71FoMoCo
Feb 23, 2003 10:18 PM
hellraiser
Feb 5, 2003 06:49 PM
