Thanks for the help. I'm definitely a Timken guy, just replaced one on my wife's trailblazer and the lady at Autozone told me her husband forbids her from bringing home Duralast even with her discount, lol. Off to bed but I will definitely check out Rock Auto. How do you order from them through here or is there a discount code?
The reason for the metric thread studs are for tourque rating
As for a 4x4 or 8 lug. It is bigger in size than the coarse thread for that reason
The coarse thread will have a lower torque sheer rating and will not fit in the bigger metric stud holes.
Fine threads will have a 6-10% increase in efective stress area of thread on comparison to coarse thread
And will have more thread area in one inch than a coarse thread stud
Ah that makes sense, thanks good to know. I guess I should be thankful for the fine threads, especially the way I use my Superduty, it definitely has stood up to my abuse.
They're metric for the torque rating? No, there are higher grades in both metric and SAE.
Thread pitch for 4x4 or 8 lug, what?
Coarse threads won't fit the stud holes? Same holes for both the coarse and fine studs.
Not sure where you got that info from, but please don't spread it.
Ok maybe I'm just a stupid mechanic that has been working on medium to heavy duty vehicles and equipment for the past 15 years
Fine threat has a higher sheer rating than coarse Plain and simple
Yea I maybe a nubie to this forum but I know my s%#+
That's why I make gooood money working on heavy equipment here in California
I don't need a pissing match
that's why ford changed to fine thread on super duty
I wouldn't be caught dead using a coarse thread stud on my F550 13 mile to the gallon daily driver. Even with a higher tensile rating
Woah there, not getting in a pissing match, but a lot of what you posted isn't true. I didn't argue that fine threads have higher shear strength, that I agree with. You were saying that they switched to metric for higher strength and there are high grades in both sae and metric. You also said they switched to metric because it was bigger to get a higher torque rating and there are larger SAE sizes. I agree with your thread pitch arguments, but they didn't switch to metric just because it's stronger, there is always larger and higher grade SAE available, just like in metric.
Ford changed to the fine thread studs for a reason.
Imagine you were an engineer that got told to "increase wheel clamping force, but we want to use existing hubs, wheels, etc." Also "we do not want to change any owner's manuals, so you can't change torque numbers'"
The only solution would be to go to finer threads because there is slightly more stud cross-sectional area under the thread's minor diameter. Also those fine threads will give a higher clamping force when torqued to the same value as the coarse threads (leverage).
My guess is that this is the best method that the poor engineer had when this hot potato got handed to him.
Lou Braun
as an engineer of railroad maintenance equipment, you would be surprised how much of this goes on.
after an expensive court case involving a truck with 6 lugnuts missing from one wheel, a beaurocrat decides that you need more clamping force, but its too expensive to update the manuals, and 10 lug wheels are out of the question.
time for fine threads.
another benifit to fine threads is that your minor diameter is larger, so you get more "meat" to the fastener without changing anything else.
of course this isnt to say that coarse threads are weak.
after all, mine are still working just fine for me.
the bigger issue is the wheel bearings.
AFTERTHOUGHT:
maybe the change in thread was due to the change in wheel backspacing.
with a 0 or low offset wheel, there is very little torque on the wheels under static or straight moving conditions... of course when you are turning, things change.
with the higher offset wheels, you are CONSTANTLY applying a torque to the mounting flange, necessitating a change to higher clamping force studs.
The coarse and fine thread ones both show up for my 01 too. I got the wrong one by mistake (fine instead of coarse) and the hub fit just fine, so all I did was knock the fine ones out and install coarse ones. Cost me $32 IIRC, for the new coarse studs.
This is what I’m going through right now…return the hubs at a very high cost or change 16 studs for a bit cheaper than shipping back…
Hi Ricardo. And welcome to the forum. I just wanted to point out, in case you missed it, that you are replying to a thread that is 11 years old. Not really a problem, but just wanted you to know.
Kinda glad he did. lol
I always thought the Course threads were stronger as the thread would have more depth than a fine thread.
I can see clamping for being better with fine.
But strength I thought was with the course.
