Sponsored by: Real Truck
Question about having only one hub locked.
Old Oct 12, 2011 | 11:12 AM
Trey's Avatar
Trey
I recently accidentally drove a couple miles on pavement while having one of my front hubs engaged in the 4wd position. What are the chances that I damaged something by accidentally doing this?
Old Oct 12, 2011 | 11:24 AM
SBastow's Avatar
SBastow
None. when I bought mine one was locked and drove around until I realized it. Poor mileage though.
Old Oct 12, 2011 | 11:39 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Youre fine. The only thing that will happen is the front drive shaft and axle will rotate. All this does is put a little bit more drag on the truck. I know people who keep the passenger side one locked so if they get stuck they only have to lock the one near them
Old Oct 12, 2011 | 11:46 AM
MisterCMK's Avatar
MisterCMK
If they are going to lock the passenger side why not lock the driver side and be done with it? Different strokes I guess...
Old Oct 12, 2011 | 11:49 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Because they leave the passenger side locked 24/7 and live in the city. Cant have both locked and drive around town.
Old Oct 12, 2011 | 12:03 PM
2000silverbullet's Avatar
2000silverbullet
Sure you can, the (dry pavement) issue only comes into play when you engage the transfer case, but you can leave the hubs locked with the truck in 2wd and have no binding problems...
Old Oct 12, 2011 | 12:06 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Hmm... I thought it was locking the wheels that causes the problem. Oh well. Good to know!
I didnt say he was the smartest guy. He drives a Chevy.
Old Oct 12, 2011 | 12:08 PM
twags6's Avatar
twags6
Leaving only one locked in will also wear the spider gears in the diff faster since one side is rotating at wheel speed and the others just rotating at maybe half speed (or how ever fast the drag in the bearings makes it spin). Its best to do both or none. As long as the **** or stick is in 2WD, you're fine to drive anywhere on any pavement.
Old Oct 12, 2011 | 12:10 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Interesting. Good to know
Old Oct 12, 2011 | 12:11 PM
2000silverbullet
Haa!
Locking the hubs only spins the axles/driveshaft but will spin freely at the transfer case.
Chevy's may be different, don't know, never owned an IFS HD truck!
Old Oct 12, 2011 | 12:12 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Originally Posted by 2000silverbullet
IFS HD truck!
Did anyone else catch that oxymoron
Old Oct 12, 2011 | 12:55 PM
kd0axs's Avatar
kd0axs
Haa!
Unless he has a 1987 or older Chevy, he doesn't even have hub locks.
Old Oct 12, 2011 | 01:45 PM
XB70's Avatar
XB70
I have a manual transfer case and manual hubs. During bad winter weather I lock my hubs when I leave the house and use the transfer case as needed. Driving around all day with one or both hubs locked is not a problem.
Trying to engage the transfer case with oinly one hub locked is a problem! One day, I forgot to lock one of my hubs. Later, when I wanted to engage 4X4, the transfer case lever didn't want to engage, grinding gears like shifting a transmission without using the clutch.
Once I engaged the other hub, everything worked normally.
Old Oct 12, 2011 | 07:11 PM
P.Bronner's Avatar
P.Bronner
Actually the driveshaft WON'T turn with only one hub locked, and the unlocked side will turn backwards relative to the one thats locked. This is exactly how all the GM products since about 1989 work. They use whats known as a central axle disconnect (CAD) system which is a sliding coupler on the right axle shaft. The left side is a solid connection into the wheel hub. F-150's and Expeditions use this system also, the difference being that the CAD systems disconnect point is inside the axle housing so you can't see the inboard section of the right axle-which is the part thats turning backwards. Bottom line is you didn't hurt a thing.
Old Oct 12, 2011 | 08:43 PM
F250CCowner's Avatar
F250CCowner
If you have a Detroit locker in the front then you cannot lock both and drive around. The darn thing won't turn on pavement. At least that's how my 86 K10 is. Lockers front and rear make pretty much short work of almost all terrain. lol
