Cruise control isn't working
Old Oct 12, 2011 | 11:05 AM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Question Cruise control isn't working
Just one of the issues with this truck however I've looked through some threads on this problem and can't pinpoint it. The recall on the switch has been done, all brake lights work including the cab. Replaced the sensor on the differential this am. and still won't work. Where else to look but wiring?
Old Oct 12, 2011 | 11:51 AM
Cell's's Avatar
Cell's
Was the cruise control working before you had the recall done for the cruise control ??
I got my recall in the mail last week for the cruise control so I have to take my truck in to be done . My cruise is working now but if it doesn't after the recall , then I will take it back to the dealer to have them fix what they broke .
Old Oct 12, 2011 | 03:19 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Wasn't working before the recall either.
Old Oct 12, 2011 | 03:22 PM
grapplermi's Avatar
grapplermi
Is it manual or auto? If it's manual, I'd bet on the CPP sensor. It rides on the clutch rod, against the firewall on the inside of the cab.
regards,
Matt
Old Oct 12, 2011 | 10:16 PM
Sjones03's Avatar
Sjones03
You could also check your clock spring, under your steering wheel air bag. I had the same problem with my truck and traced it back to a bad clock spring.
Scott
Old Oct 13, 2011 | 06:37 AM
DISLFVR's Avatar
DISLFVR
Locomotive breath
regards,
Matt
It's an auto, forgot to add that to my sig. The early '99 I had had the broken cpp switch in it.
lawnspecialties
Dec 16, 2017 08:35 AM
firebug
Oct 29, 2010 06:39 AM
93f250tn
Jan 10, 2010 06:17 AM
95250mac
Mar 4, 2009 11:43 AM
silverxlt
2004 - 2008 F150
Mar 3, 2006 08:36 PM
