well i still need help
Old Oct 11, 2011 | 10:10 PM
brokeisnojoke's Avatar
brokeisnojoke
Does anyone live in north west Ohio? I need help on this damn truck
Old Oct 11, 2011 | 10:22 PM
tshrager's Avatar
tshrager
Columbus. Whats the problem?
Old Oct 12, 2011 | 05:09 AM
brokeisnojoke
My truck has been down for a while and I can't seem to figure it out. Iv changed cps, ipr, idm, filled hpop, checked hpop pressure. Injectors won't fire I can't even get any smoke
Old Oct 12, 2011 | 05:13 AM
brokeisnojoke
Ill dig my old thread up.
Old Oct 12, 2011 | 07:45 AM
tshrager's Avatar
tshrager
That blows. Im pretty busy at the moment. Where at in northwest?
Old Oct 12, 2011 | 10:02 AM
brokeisnojoke
I live in van wert. Its like 40 mins east of ft. Wayne indiana
Old Oct 12, 2011 | 11:28 AM
tshrager's Avatar
tshrager
That's a bit far for me. Sorry I couldn't help. This sounds redundant, but have you had the codes read?
Old Oct 12, 2011 | 12:23 PM
DIYMechanic's Avatar
DIYMechanic
Yeah, sorry, That's 2 plus hours from me as well.... that's on heck of a wind farm you guys have got over there! I drove through that area a couple months ago on 30 and was absolutely blown away at the number of wind turbines.
Anyway, (back on topic) about those codes.... or a link to the old thread....We will help you if we can.
Old Oct 12, 2011 | 01:47 PM
brokeisnojoke
Ya there are several more here now. They go up by twos daily. Here is a recap: truck died while driving, cps code came up. New cps started it 2to times and then nothing. While it was running. Injector pressure higher or lower than desired, so I put in a new ipr. Still nothing. I got an idm from a running motor but still will not fire. Hpop got drained from doing the ipr so I topped it off. No burnt wires on harness or anything. I have no smoke from the exhaust either
Old Oct 12, 2011 | 01:52 PM
DIYMechanic
Alright, we're back on track. Where did the new CPS come from? If it's not from Ford or International, I would try another.
Have you checked Fuse 22 under the hood?
Just going through the basics to get this going again...
Old Oct 12, 2011 | 02:39 PM
mountaineer27's Avatar
mountaineer27
yeah i would try another cps. so of the cheep ones can go bad days after install.
Old Oct 12, 2011 | 03:08 PM
brokeisnojoke
Tac moves and I have checked all maxi fuses under the hood
Old Oct 12, 2011 | 03:17 PM
Ken_C's Avatar
Ken_C
no smoke eh? is it getting any fuel at all? whats the fuel pressure? have you changed the fuel filter recently? is it in correctly? it needs to be installed right or you will not get any fuel past it. only reason i ask is my cps and fuel pump failed at the same time once. and i had to be schooled on the fuel system on these beasts. good luck with it.
brokeisnojoke
Cps came from advance
Old Oct 12, 2011 | 03:19 PM
Ken_C's Avatar
Ken_C
also, how much fuel is in it? i have heard the fuel pickup tube can break on our trucks which depending on where the pickup breaks you will run out of fuel and still read plenty on the fuel gauge.
