Dual Exhaust
Old Oct 11, 2011 | 09:26 PM
mtntop1's Avatar
mtntop1
Dual Exhaust
Approximately how much of a horsepower gain can I expect by converting to dual exhaust using stock mufflers and exhaust manifolds on my 1995 F150 5.0L.Also what problems should I expect.
Old Oct 11, 2011 | 09:33 PM
86F150302's Avatar
86F150302
None..
Why and how would you ever run dual exhaust with the stock muffler..
Old Oct 11, 2011 | 09:38 PM
'89F2urd's Avatar
'89F2urd
lots of work with no gain.
if youre keeping factory tuning, even the highest flowing "true duals" will do nothing for you. long tubes into a y-pipe will net you the greatest seat of the pants gain vs any other setup, short of a "racecar-esque" top end setup, where true duals will net the greatest gains in high rpm (horrible for a street driven truck)
get long tubes, fab a free flowing 3" y-pipe, and just run the single.
Old Oct 11, 2011 | 09:47 PM
mtntop1's Avatar
mtntop1
I am trying to gain some horsepower to tow a travel trailer.
Old Oct 12, 2011 | 04:09 AM
lew52's Avatar
lew52
Long tube headers with a custom exhaust is your best bet , what gears are in the truck , and tire size ?....
Old Oct 12, 2011 | 08:16 AM
mtntop1's Avatar
mtntop1
exhaust
I am also trying to keep it quiet as possible.
Old Oct 12, 2011 | 08:36 AM
rla2005's Avatar
rla2005
Your biggest gain in HP and MPG for the money is replacing the factory y-pipe/converters with a high-flow version. Whether you want to go the extra steps for long tube headers and a custom exhaust is up to you.
Old Oct 12, 2011 | 08:43 AM
mtntop1's Avatar
mtntop1
Thanks
Are there any other ways to increase HP on a budget.My pockets aren't to deep.
Old Oct 12, 2011 | 09:43 AM
rla2005's Avatar
rla2005
A tune up with good quality plugs, wires, cap and rotor as well as filters. Bump the timing up a few degrees.
Old Oct 12, 2011 | 09:56 AM
SCRebel's Avatar
SCRebel
only things duals might give you it better mpg, but thats without cats, or with high flow.
Also like Rla2005 said, do a good tune up. I run my timing at 15 degrees, book calls for 10.
Also how many miles are on your motor, and how long since the timing chain was replaced?
A wore chain will cut your power, cause the cam will be laging behind alittle
Old Oct 12, 2011 | 11:20 AM
mtntop1's Avatar
mtntop1
144,000 miles on motor,timing chain never replaced.
Old Oct 12, 2011 | 11:33 AM
86F150302's Avatar
86F150302
Everyones budget is different.
Whats yours and we can help you out more.
Old Oct 12, 2011 | 11:43 AM
mtntop1's Avatar
mtntop1
A few hundred bucks.
Old Oct 12, 2011 | 02:27 PM
SCRebel's Avatar
SCRebel
It wouldn't hurt at all to replace the timing chain, get a double roll timing chain. There about 30-40 bucks, but the timing chain cover has to come off the front of the motor.
Old Oct 12, 2011 | 05:06 PM
mtntop1's Avatar
mtntop1
Thanks to everyone for the great suggestions.
