new guy has questions
Old Oct 12, 2011 | 10:12 PM
  #31
jack.dubord's Avatar
jack.dubord
So i bought the hpx mode from riffraff and was talking to him about a remote oil cooler. i told him how hot i was getting on my oil temps and he said that my truck does not have oil temp readings. It may be false readings so i have a edge cs chip and it tells me the temp from the pcm so do any of you guys know if this is true or not
Old Oct 12, 2011 | 10:57 PM
  #32
oldbird1965's Avatar
oldbird1965
I don't know anything about a edge cs chip but I have both the mechanical gauge and a scan gauge and both say about the same thing. The scan gauge gets its reading from the PCM. The other gauge is plumbed into my oil bypass filter system.
Old Oct 12, 2011 | 11:31 PM
  #33
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Possible bad sensor as well. Easiest way to check is use an IR gun and see what your reservoir temp is. That will get you close.
omahaford
Apr 27, 2016 11:46 PM
Splatts
Dec 28, 2011 09:23 AM
EMD_DRIVER
Feb 5, 2011 10:52 PM
79_250RangerLariat
Mar 10, 2008 07:14 PM
jdecker88
Oct 6, 2007 06:02 PM
