went to Cruzin the Coast this past weekend and saw a couple of nice 53s... both had what appeared to be a factory made trailer hitch hidden under the bed. One exited thru the bumper and the other thru the roll pan...
wondering if any of you have a factory made hitch... what brand. model and what it fit originally ??? need to think about this before we get the bed/roll pan all fabbed up and forget it... it's also got to fit in there with the mustang tank.. gonna get a little crowded...
John, I found this one advertised. It looks like it mounts further in on the frame, and then an extension is installed when you are going to use it. Jag Hidden Hitch Trailer Hitches for your Truck or SUV
<TABLE class=singleProduct cellSpacing=0 cellPadding=5 width="100%"><TBODY><TR><TD height=130 width=130 align=middle> <SMALL>Click to View</SMALL> </TD><TD>Want to tow with your Classic without that ugly hitch hanging below your bumper? Our new Hidden Receiver Hitch is just the answer. Designed for use with the stock '67-’72 factory rear bumper, simply flip up the rear license plate and insert the coupler. It’s that easy. Hitch is rated for up to 500lbs tongue weight and 5000lbs total trailer weight.
We now offer the hitch components in a package deal: Hidden Receiver Hitch, Extended Ball Mount, License Plate Flip Frame and Flat Four Trailer Wiring.
Our new Blazer and Suburban hitches are also finished and in stock, and feature the same quality design and powder-coated finish as our Pickup version. Drilling is required for installation, and every hitch comes with all needed hardware.
</TD></TR></TBODY></TABLE>
Earlyclassic enterprise sells a hidden hitch that fit the early 60 to 72 chevies. the frame is the same width of our Fords
John... you are da man !!! that's exactly what I was looking for... gonna call tomorrow and verify a few measurements... I have the Mustang tank out back and have to make sure I can squeeze it all in...
thanks man... and thanks to all with suggestions and ideas... THAT'S why I love this place !
I used a dodge hitch on my 54 F250 and it was the right width. I bought it about 10 years ago when "Orschlens" was having a close out. I measured the width and it bolted in to the bolt holes for the rear bumper bracket and only had to drill two more holes. The receiver is about flush with the back of the bed.
I have more length with the long bed, so that might not be an option for a short bed.
some of the older gm cars had flip down license plates, 69-70 clevelles, gto, the mechanism is easy to remove as its bolted to the bumper
My mom's 69 Impala had the flip down license plate. I used to think that was a bad place for a gas filler (what with a rearender), but it had a massive chrome bumper that was made out of the same metal they make skillets out of.
