Coolant Flush Question
Old Oct 9, 2011 | 02:44 PM
wgcdc's Avatar
wgcdc
I am planning to do an EGR upgrade/delete, oil cooler replace and possible new exhaust system over the Thanksgiving break. Can I/should I do the coolant flush now or should I do this right before doing the upgrades?
Old Oct 9, 2011 | 03:48 PM
U.P. Builder's Avatar
U.P. Builder
I'd do it now, let the old oil cooler filter the crap out after the flush rather than the new one.
Old Oct 9, 2011 | 03:57 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Are you seeing a big EOT/ECT delta or are you doing it to avoid problem later? If the truck is fine now, it will prob be fine either way. Maybe a little easier to do it all at once. If there is an issue, doing it now might be better. Then when you do the work you can eyeball the coolant to see if it may need to be done again.
Old Oct 9, 2011 | 08:24 PM
wgcdc's Avatar
wgcdc
My EOT/ECT delta averages around 5 - 7. It gets around 7 – 10 on the interstate (not towing). Towing an 8,000 lb travel trailer it gets a good bit higher than 10 in climbing grades in the mountains. Since I am a newbie I wanted to get as much work done before I tackle the EGR/Oil Cooler project. I have already installed a coolant filter.
Old Oct 9, 2011 | 08:34 PM
bpounds's Avatar
bpounds
Gosh, that's not bad. Are you sure you want to jump into replacing the coolers? How much over 10 while towing? Even a solid 15 is not too bad while towing.
I would NOT use the VC-9 cleaner unless I was committed to the likelyhood of needing a new oil cooler. But you can do a distilled water flush and fill anytime without worry of doing any harm. Sounds to me like that is all you need.
Old Oct 9, 2011 | 08:45 PM
wgcdc's Avatar
wgcdc
I was wondering about that. The truck has 108,000 miles and I thought the upgrades were good idea for reliability. The towing delta was around 15 and peaked at 20 for short periods. The delta dropped pretty fast once I got off of the steep grade. The grade was very steep for about 15 minutes, she was working hard.
Old Oct 9, 2011 | 09:08 PM
bpounds's Avatar
bpounds
...The delta dropped pretty fast once I got off of the steep grade...
This is a key indicator that you are getting a good heat transfer. I really don't think you have a problem. New coolant is always a good idea regardless.
Changing coolers that have not failed/clogged is not a reliability upgrade IMO. Unless you just feel like you want to Bulletproof it and have cash to burn.
Old Oct 9, 2011 | 09:56 PM
BLADE35's Avatar
BLADE35
X2 here as well
your numbers are about the same as mine and my oil coo;ler only has 5000 miles on it
dont mess with it
U.P. Builder
Agree with bpounds, your deltas are good. Just dump the coolant, do some distilled flushes and refill. Feel blessed.
Old Oct 10, 2011 | 08:51 PM
kidoo's Avatar
kidoo
Do you thing Restore would help?
Old Oct 10, 2011 | 08:56 PM
wgcdc's Avatar
wgcdc
Thank you for the help. I'll skip the oil cooler replacement. I bought the truck new and I take very good care of it. I'll flush it several times with distilled water as you suggest. I have the same question as kidoo should I use any of the flush chemicals?
Old Oct 10, 2011 | 10:03 PM
bpounds's Avatar
bpounds
I don't think you need any cleaners. Will certain ones hurt anything? I do not know if they would. Unless you know, why take a chance?
Old Oct 10, 2011 | 10:11 PM
Snuggyworm's Avatar
Snuggyworm
if ur gonna use restore, dont forget to pick up some restore plus as well. use them both. restore is for initial cleaning, then restore plus cleans corrosion and lime away. best of luck fellas.
Old Oct 10, 2011 | 10:13 PM
BLADE35's Avatar
BLADE35
If you start running cleaners and such thru it you might break junk loose and plug your oilcooler
The Risk is there for shure
theres been a few folks that have flushed with cleaners and made the spread Worse
Old Oct 10, 2011 | 10:42 PM
Snuggyworm's Avatar
Snuggyworm
hmmmm, tats interesting. i'll keep tat in mind.
