Fuel guage issue
Old Oct 9, 2011 | 02:24 PM
motomech10's Avatar
motomech10
Fuel guage issue
1987 F150 4.9L single tank
Replaced sending unit, checked wiring and power through the circuit. As far as I can tell the guage itself may be faulty. Is this common problem for this model year? Can I replace just the fuel guage or would it have to be the entire instrument cluster or should I just install an aftermarket guage?
Suggestions, ideas?
Thanks
Old Oct 9, 2011 | 05:37 PM
motomech10's Avatar
motomech10
UPDATE
I pulled the instrument cluster and fuel/Oil pressure guage unit out and directly tested the fuel guage. I found a burnt spot (open) on the positive+ power circuit to the guage in the flexible circuit board. It appears the guage itself is faulty also. I can get the needle to swing one way, but not the other. I suspect whatever caused the short in the positive circuit, may have fried the guage also. Hopefully a replacement will fix it.
This is a picture of the complete unit with a close up of the guage itslef removed from the unit in the bottom half of the picture. I'll try to follow up once I try a replacment.
JayzDaddy
Aug 27, 2014 02:49 PM
joe f350
Mar 13, 2011 07:51 PM
Bookman
Nov 8, 2007 10:23 AM
tayracing
Jul 14, 2007 06:16 PM
AaronW
Oct 24, 2001 12:57 AM
