Reverse lights
Old Nov 16, 2002 | 12:11 AM
bourbon's Avatar
bourbon
Reverse lights
Old Nov 17, 2002 | 12:05 PM
87granny302's Avatar
87granny302
Reverse lights
The truck is a 87 F150 4x4 with a manual transmission. Reverse lights don’t work and I think it's because the switch is missing from the transmission. There is a 2 wire plug hanging on the drivers side, by the clutch that has one wire hot at KOEO. There is hole in the tranny close by, cant tell if its threaded or not though. Is this where the reverse light switch goes? It's a granny gear 4 speed but I'm not sure which one. I understand that Ford put several different ones in these trucks. I had seen an earlier post that had a link to a site that would help me identify it, can anyone give that to me? Thanks.
Old Nov 17, 2002 | 12:40 PM
87granny302
Reverse lights
Oops, that hole by the clutch salve cylinder isn't even the transmission. So now I dont know where to look for the reverse light switch.
Old Nov 17, 2002 | 01:46 PM
steve83's Avatar
steve83
Reverse lights
http://www.motivegear.com/tech_info/tranny_guide/tranny_guide.html
The reverse switch is usually screwed into the side of the top cover on top-loaders.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
