I have two possible carbs to put back on my rebuilt 390, one is a Carter 625 cfm AFB, the other is a Holly 4bbl, but I do not know what model it is or the cfm rating. The Holly has a toe tag that reads D4Te ASA 4D25.
Does anyone out there in Ford land know what type of carb my Holly is ?
I can't ID your Holley. But, If the Carter is in decent shape, I'd reccomend trying it first. It should be a good flow match and reasonably easy to tune.
Originally posted by Steve 97439 I have two possible carbs to put back on my rebuilt 390, one is a Carter 625 cfm AFB, the other is a Holly 4bbl, but I do not know what model it is or the cfm rating. The Holly has a toe tag that reads D4Te ASA 4D25.
On the choke tower there should be a "list" #.
Try posting that, it might be easier to ID that way!
