6.0 wont start
Old Oct 8, 2011 | 06:07 PM
joe4m's Avatar
joe4m
Trailering
Ithought slammed03,s was an 06 and it wont start cold or fire just cranks put both new fuel filters , cheched the voltage to the ficm it was 48 when the key was on but do i need to check it while crankin?
Old Oct 8, 2011 | 06:21 PM
NewToDiesels's Avatar
NewToDiesels
Yes.
Full testing procedure at the top of the Tech Folder.
Old Oct 8, 2011 | 06:25 PM
BLADE35's Avatar
BLADE35
you maybe right ON Year
I just figured he had an 03 due to his screentitle
do you have any gauges
you need to see what your running for ICP can also be done with a DVM
Old Oct 8, 2011 | 06:54 PM
slammed03's Avatar
slammed03
[QUOTE=BLADE35;10899978]you maybe right ON Year
I had to think of something quick cause my phone was dying,its my screen title from svt performance for my 03 turbo cobra. Any ideas on where to find those parameters I need I have xcal 2 with live link 6.3
Old Oct 11, 2011 | 07:43 PM
slammed03's Avatar
slammed03
Does the xcal 2 have ficm sync,icp sync, ficm-m-pwr? If not what might be something I can use,truck is still dead and everybody just keeps saying "probably just need to keep cranking"I did for 3 days,doesn't work. This thread is several days old so please read previous post before saying just keep cranking
Old Oct 11, 2011 | 07:52 PM
BLADE35's Avatar
BLADE35
well dont keep cranking LOL
mine has always started before batts went dead
did you get the FICM ground back on the intake manafold bolt in the back
and have yo checked all the fuses
NewToDiesels
Did you check your FICM power using the procedure in the tech folder (you just need a voltmeter and someone to turn the key)? Did you check your FICM connections? Did you check your IPR valve screen?
I don't know anything about your scanner, can't help you there...
Old Oct 11, 2011 | 08:02 PM
BLADE35's Avatar
BLADE35
I dont know anything about your xcal 2 either
I did look at your readings you posted awhile back dont really know wwhat Im reading there either
Did you check the FICM volts while cranking
Old Oct 11, 2011 | 11:02 PM
slammed03's Avatar
slammed03
Never disconnected the ficm connections so I'm good there. The ficm ground is connected and the ipr valve screen is clean. I got 48 volts steady from the ficm while cranking. all fuse are good,not sure about the relays as I would need to apply the correct operating voltage ( probably 12) to see if they switch.
Old Oct 12, 2011 | 07:00 PM
slammed03's Avatar
slammed03
does anybody know how to moniter parameters with a xcal 2 or which ones i should moniter to get my truck atleast started? my trucks been down for over 3 weeks. what scan tool does everybody else use to get icp pressure,ficm sync.....this thread has got me nothing better than a popped hood with no answers
Old Oct 12, 2011 | 08:54 PM
BLADE35's Avatar
BLADE35
Thats the problem I dont know to many guys that use X-Cal 2 in fact you the only one and I cant understand its readings that you posted
I use Scan Gauge II and a bunch of folks on here do too its a GREAT Gauge for 160.00 It will get ICP,IPR,CAM/crank sync,ficm sync,ficm volts,eot,ect,map,ebp,egr,baro and a ton more
check it out
www.scangauge.com
and then if you need to do testing of stuff lets say injectors or vgt then everybodys using an Auto Enginuty its like 370.00 with the ford bundle from riff raff diesel talk to Clay
AE will do everything SG does plus cylinder balance test and other tests it has the ability to control things to test
AE is the way to go if you can swing it
Riffraff Diesel Performance Parts | Ford 7.3 diesel | 7.3 powerstroke | Ford Powerstroke | 7.3L Powerstroke Parts?
maybe you did but make shure FICM conectors fulley plugged in one may have got bumped during turbo install
I just think it has to be related to the work
oh 1 more thing have you checked the fuses??????
Old Oct 12, 2011 | 09:18 PM
NewToDiesels
Or you can pull it to the dealer and ask them to run diags for you for about $100. Then you can do the work yourself.
Sometimes you gotta do what you gotta do...
Old Oct 13, 2011 | 07:55 AM
  #28
Unrealo4's Avatar
Unrealo4
Check the fan clutch wires. Unplug and try to start. Also check the fuel pump inertia switch. That's in the passengers side kick panel.
Old Oct 13, 2011 | 09:45 AM
  #29
slammed03's Avatar
slammed03
Checked all fuses good but not the fan clucth never thought of that one,I had a friend check it with a genesis scan tool thing cost like 5k damn! But he said ficm sync and voltage are good icp is good plenty of oil pressure and crank and camshaft sensor sync.....but the scan tool did say 6 out of 8 cylinders are not firing,it also tells possible causes: remove aftermarket tune,ficm needs calibration and thered was a couple more but I can't remeber is it possible the ficm lost calibration when I disconnected the batteries,they should hold memory??
Old Oct 13, 2011 | 10:11 AM
  #30
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Disconnecting the batteries won't affect FICM programming.
When you see a bunch of injector codes like that the FICM is suspect. Passing the voltage test doesn't necessarily mean that there's nothing wrong with it.
