I just put all new Energy suspension poly bushings in my front end, sping and pivot. I've only gone for one test drive but it rode great, even with the add-a-leaf I installed as well. Moog does have a good reputation, I wouldn't hesitate to use them.
i got mine from LMC. the factory replacement ones. mine were completely shot and let me tell you those were a pain to get in and out. lot of heat from the torch. pounding with the air hammer. and pressure from the press got um out. was not fun.... lot of very delicate pressing to get the new ones in with penetrating oil. if i do it again i will be going with the 2 piece design ones for sure
One thing to keep in mind is that originally the trucks came with 9/16 bolts which fit the bushings pretty well. They went to 14mm bolts without changing the bushings so those bolts are pretty loose in the bushings. You don't want them tight but you don't want them loose either..
I used a ball joint press to remove the old bushings. Still needed a screwdriver and hammer to get the shells out though. The press was needed to install my pivot bushings as well.
