SRL+ Question
Old Oct 7, 2011 | 10:44 PM
_Me2_'s Avatar
_Me2_
SRL+ Question
With this tune, I'm only hitting about 20 PSI at WOT. If I'm already rolling in a higher gear and ease into it, it will build into the high 20s or so for a bit, but will be back to about 20 before long. Is this normal behavior for this tune? It still has a ton of power and seems to run great, but seems a bit odd that the boost is so much lower than before.
Old Oct 8, 2011 | 01:27 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
is that pressure read off the instrument cluster gauge?
or
an aftermarket gauge?
you should be easily hitting 30 psi...some guys I've talked to see 40+ psi if they stay into it very long. Remember that the inst. cluster gauge isn't correct when tuned
Old Oct 8, 2011 | 01:54 AM
_Me2_'s Avatar
_Me2_
Instrument cluster. I didn't know they were inaccurate when tuned, as I had read that they were about the only gauge that was accurate in the cluster.
Old Oct 8, 2011 | 03:02 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
stock tuning and that gauge is accurate to within 5 psi
you really need an aftermarket gauge. I wouldn't be surprised if you are seeing 35 psi most times.
My truck before tuning was hitting 25-27 psi at WOT before dropping down to 20-24 psi. Now, I haven't seen it break 20 psi myself. I've got my gauges sitting in the garage for when I've time to install
Old Oct 8, 2011 | 08:27 AM
npccpartsman's Avatar
npccpartsman
I've never read or heard that before nor have I experienced it in the past 145K miles that my truck has been tuned.
If you have your EGR deleted or the valve unplugged then depending on your flash strategy you could be limited to about 20 psi and FWIW--anything over about 28 or 30 and the stock turbo starts to "choke".
Old Oct 8, 2011 | 09:23 AM
69cj's Avatar
69cj
1st time I've heard that in the six years I've been coming here and other forums. The stock gauge could use some better incrementation but that doesn't equate to inaccurate.
Old Oct 8, 2011 | 09:32 AM
_Me2_'s Avatar
_Me2_
I would hit 28 or so all day long before tuning. I had the studs done and a bulletproof EGR cooler put it, so the EGR valve is in place and plugged in, although turned off in the tuning. I guess I'll do some experimenting this weekend with the other tunes including stock and see what happens.
Old Oct 8, 2011 | 11:57 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Talk to Matt. I'm surprised he didn't tell you. He made sure I knew that the inst cluster gauge wouldn't work properly with his SRL. I've read the same over on PSN several times by other people as well
It may just be an aspect of the Gearhead tune that other tuners don't have????
Old Oct 8, 2011 | 12:20 PM
_Me2_'s Avatar
_Me2_
No, he didn't. I thought about asking him but figured I'd try here first. I'll see what he can tell me.
Old Oct 8, 2011 | 01:08 PM
rdunagan's Avatar
rdunagan
yea he told me all i would see on my gauge was about 20 or so but as long as i dont hear a boom! im happy with it since it has tons of power. more boost out of a tune doesnt always mean power. i ran a tune once on my dually and on an accurate gauge i would only hit 23 psi and it still ran dang good!!! to me if i run over 30 psi it scares me to no end! unless you hear or see an exhaust leak i would say leave it alone
Old Oct 8, 2011 | 02:26 PM
_Me2_'s Avatar
_Me2_
He just let me know that it will read about 5-7 PSI lower than it actually is, nothing that it is "part of the trick."
I've got a bit of experience with forced induction in other vehicles, so I know that power is related more to the volume of air going in than the PSI. However, since no physical changes were made to allow the flow of more volume, I knew that I would not be making so much more power while having significantly less boost, thus the confusion. Good to know it's just an issue with the gauge reading. I like to make sure the potential problems are addressed before they turn into real problems. Thanks, guys.
Old Oct 8, 2011 | 02:36 PM
william_04_x's Avatar
william_04_x
A tune will change a lot of what the PCM thinks it see's with the manipulation of how sensor data is interpreted/reported to it. I didn't know the factory boost gauge was affected, but it doesn't surprise me either. I'd love too hear what you guys see with a mechanical gauge tapped to the intake elbow.
Old Oct 8, 2011 | 02:46 PM
npccpartsman
That is interesting information. Maybe that's why my datalog of his tune only shows 32 psi when the manual gauge was hitting 37+. I'll have to go back and check the MAP sensor reading.
Old Oct 8, 2011 | 02:53 PM
william_04_x
First I saw something like this was when the ICP Xgauge first got released. When I was tuned the numbers seemed too low. I verified this after my buddy hooked up an analog HPOP gauge and I plugged my SGII in while we made some passes. Hard passes with aggressive tunes pegged the analog(4000psi), and the SGII would report much lower ICP numbers(around 2800 IIRC) at the same moment.
Old Oct 8, 2011 | 02:57 PM
npccpartsman
I know the ICP is manipulated to get much longer pulse width without running out of HPO. I didn't know the MAP was manipulated also, but I understand why, especially if the newer Ford flashes "limit" boost.
