Code help
Old Nov 3, 2011 | 09:42 AM
ggirten's Avatar
ggirten
Originally Posted by TXtinct
Okay, I replaced the GPCM and that fixed the no start issue I ended up having. Got two new codes.
P0672 GP# 2 Circ failure
P1316 Injector circ/IDM codes detected
Runs fine and smooth, what am I dealing with here?
Sounds like your inside valve cover harness may be loose. Try the quarter fix. Pull the valve cover off. If the connector is loose, then grind a quarter down until it just slips under the clip.
Old Nov 3, 2011 | 09:48 AM
TXtinct's Avatar
TXtinct
You'll shoot your eye out
That's kinda what I was thinking, will that take care of both codes you think?
Old Nov 3, 2011 | 10:21 AM
ggirten's Avatar
ggirten
If it's loose, it should.
Dr.Huxtable
Jul 27, 2020 03:33 AM
waterboy_fishing
May 25, 2013 08:23 AM
musubee
Nov 17, 2009 02:26 PM
truckeemtnfords
13
Dec 23, 2008 10:13 AM
dieseldave2
Sep 27, 2004 01:18 AM
