1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Alignment cams
Old 10-11-2011, 12:08 AM
hotroddsl's Avatar
hotroddsl
hotroddsl is offline
I used to take my trucksup to Gary in Deer Valley, He would set them up for me old school, and they were always perfect! But that's just to far now I'm in South Gilbert is Gary' Alignment still open? On 19th just north of Deer Valley? Really a good guy honest and dependable.
Jim & fat Monty
  #32
Old 10-11-2011, 07:55 AM
Monster-4's Avatar
Monster-4
Monster-4 is offline
Originally Posted by Krewat
Mike, that sheet looks like a brain-scan!
That Moog adjustable sounds like this (if link comes up right):
NAPA AUTO PARTS
At first, I was thinking one of the 2.25 or 2.5 degree cams would work, because they have 8 separate "cogs" to orient the cam, and just put it one cog off, but that would be far more camber than just .5 degrees.
I always thought it looked like a brain scan as well. It resembled my brain, with all the holes in it, the first time I looked at the sheet.
Your link didn't work but if it was part number NCP 2643951 that looks like the exact same thing. Below are the instructions I have. It seems straight forward I just need to find a puller that can be tighted down horizontally. Looks like OTC makes 7310A or 7311A that would work for this. Not sure such a puller is needed though. Might just be able to pry under the bushing and work it out.
Name:  dual axis instructions.jpg
  #33
Old 10-11-2011, 08:08 AM
Monster-4's Avatar
Monster-4
Originally Posted by mwsF250
Did you put the Moog ball joints into your stock sleeves?
If so, that would indicate they are very similar in size!
Good point and yes I am using the stock bushing so...
PS: I've found some alignment guys to be full of, well, doo doo. But they spew doo-doo with great authority!
...your point is proven!
I've had an alignment one time that made my truck handle so bad I could barely control it sometimes. So in my driveway with straight edges and tape measures I found one of the front wheels had about 4 degrees of toe in! The other was 0. I hand aligned it but made an appointment at another very trusted truck shop anyway. Came to find out I was within 1/32" from alignment. Not to bad considering my "primitive" method.
  #34
Old 10-11-2011, 06:05 PM
mwsF250's Avatar
mwsF250
mwsF250 is offline
Dang, what a wonderful thread! I printed out the attachments and PN's for when I have to align my truck. I've never dealt with solid axles before, so wasn't fully understanding how to tweak caster without affecting camber, and vice versa. The Moog/NAPA dual axis system seems to make it easy.
THANK YOU for posting!
  #35
Old 10-11-2011, 06:16 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Mike, that bushing came right out for me - after using the HOT WRENCH.
I then applied anti-seize when I reassembled with the new balljoints.
If you're not changing the ball joints, I don't know how you'd get that thing out of there.
let me think on it...
  #36
Old 10-11-2011, 09:39 PM
Monster-4's Avatar
Monster-4
According to the workshop manual you should be able to use a puller similar to the OTC 7310A or the 7311A to pull the bushing. I'll need to find a 1/2" drive crowfoot wrench big enough to fit the lower ball joint nut though to be able to torque it back to spec.
  #37
Old 10-12-2011, 12:28 PM
mwsF250's Avatar
mwsF250
mwsF250 is offline
And now the installation procedure and torque figures?
Where will the goodness end?
Maybe I should post my address.... You guys might as well just swing on by and do all the physical work for me as well!
  #38
Old 10-12-2011, 12:38 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Looks like that NAPA piece I found at NAPA is this by McQuay-Norris:
http://www.amazon.com/McQuay-Norris-...dp/B000EIZSWS/
Not sure I want 3/4 degrees of camber though.
  #39
Old 10-12-2011, 05:12 PM
Monster-4's Avatar
Monster-4
Anything to give back to everyone at FTE! BTW if you were closer I would come over and lend a hand.
  #40
Old 10-12-2011, 07:40 PM
Monster-4's Avatar
Monster-4
Amazon.com: McQuay-Norris AA3951 Caster - Camber Bushing: Automotive
That would put you at a +1/4 camber and spes are -3/8 to +1 5/8 so that's still pretty good.
  #41
Old 10-12-2011, 08:03 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
True, just trying to keep camber exactly what it is now - no weird tire wear for the past 11 years, so...
Of course, that was with the ball joints loose, so an extra 1/4 degree is nothing...
BstangBill
09-22-2016 01:48 AM
TylerF100
09-10-2016 03:34 PM
jimmycoc
08-25-2011 08:44 AM
mackdog
05-06-2006 09:40 PM
Cor
21
09-08-2004 02:46 PM
Quick Reply: Alignment cams
