1978 - 1996 Big Bronco
78 bronco
Old Oct 6, 2011 | 09:27 PM
Northern Caveman's Avatar
Northern Caveman
Question 78 bronco
what is the bigeest size of tire can u put on a stock 78 bronco i want to go 35's
Old Oct 6, 2011 | 10:50 PM
Edgethis's Avatar
Edgethis
If the springs are in good shape you might be able to fit them with some rubbing. 33's for sure will fit.
Old Oct 9, 2011 | 12:17 AM
Bgasrickshaw's Avatar
Bgasrickshaw
I have 12.50 35s on one of mine and they rub on the radius arms if you turn lock to lock, otherwise they are o.k.
Old Oct 9, 2011 | 03:18 AM
ErrorS's Avatar
ErrorS
just find some different wheels to deal with radius-arm rubbing. Found some stock steel wheels off of an old 80s Jeep, $150, they look sweet and have that shallow Jeep backspacing that make your tires sorta stick out.
Turned in my steering stops crazy far, so now I have an insanely tight turning radius that embarasses most small cars.
Old Oct 11, 2011 | 06:09 AM
miottimouse's Avatar
miottimouse
i tried 35s and they rubbed on the front fenders 33s fit nice
Old Oct 14, 2011 | 09:05 PM
Northern Caveman
ok so 35's will fit then i got those white steel rims you seen on most older fords there 15x 8 i think the fenders or f#$% up so if they have to they will be cut bronco been rolled its never going to seen the highway
ErrorS
Offroad & 4x4
Feb 7, 2010 12:30 AM
Yakima5019
Jun 16, 2006 02:15 AM
BootHill
Jun 7, 2005 01:18 PM
rshissler
Apr 3, 2005 10:59 PM
1970Custom
Dec 13, 2004 02:14 PM
