Wiper Switch
Old Oct 6, 2011 | 09:06 PM
Tony_C's Avatar
Tony_C
Wiper Switch
I finally got around to checking out the wiper switch and motor on my 62. The wipers would start, then stop, then start, and on and on. When first running the wipers they stay on a minute or so before stopping and starting. I pulled the switch and could actually hear the switch making a little pop/spring noise right when they cut out. Plus its warm to the touch when it stops. So to me it sounds like it's getting hot and causing this.
So I'm thinking the switch is the culprit and want to replace it. The part number on the switch is C5TG17A553E. Anyone know if this is the right switch for a 62? And if so, where can I get one?
Old Oct 7, 2011 | 04:26 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
So I'm thinking the switch is the culprit and want to replace it. The ID engineering number on the switch is C5T G -17A553-E
Look at this ID number again, because it cannot be correct.
There is no ID number prefix for any wiper switch that begins with C5T and no wiper switch ID prefix contains a G as the 4th digit. Only a B or an F was used.
There are two different wipers switches for 1962, one for single speed wipers, another for 2 speed wipers.
Marked: C2TB-17A553-A or C2TB-17A553-C = C2TZ-17A553-A .. Single Speed Wiper Switch-3 terminals / 1962 F100/600 / Obsolete
47 available NOS from FoMoCo Dealers/obsolete parts vendors.
Marked: C1TF-17A553-C = C1TF-17A553-C .. 2 Speed Wiper Switch, 4 terminals (Motorcraft SW719) / 1961/62 F100/950 / Obsolete
11 available NOS from FoMoCo Dealers/obsolete parts vendors.
IF the switch is marked C3TB-17A553-E = The Ford part number is C3TZ-17A553-E = 4 terminal 2 speed wiper switch / Obsolete
Applications: 1963/65 F100/950 / 1963/66 Econoline / 1966 F100/350 before serial number 760,001 / 1966 F500/950 before serial number 802,001.
1961/66: This is the only wiper switch ID number that has an E for a suffix.
If your 1962 F100 has 2 speed wipers, it's possible someone used this switch in place of C1TF-17A553-C because they couldn't find one. Or...
Maybe you have a 1963 F100. What are the last 6 digits of the VIN?
Old Oct 7, 2011 | 08:09 AM
jstephens2's Avatar
jstephens2
I rencently pulled a switch and motor off a 1979 ford, it worked out great and now i have two speed wipers
Old Oct 7, 2011 | 10:27 AM
Tony_C's Avatar
Tony_C
Look at this ID number again, because it cannot be correct...
...IF the switch is marked C3TB-17A553-E = The Ford part number is C3TZ-17A553-E = 4 terminal 2 speed wiper switch / Obsolete
If your 1962 F100 has 2 speed wipers, it's possible someone used this switch in place of C1TF-17A553-C because they couldn't find one...
Thanks Bill!
Geez, I need better glasses...and not try to pull a part number in the dark. It (in the light of day) actually is C3TB-17A553-E. My truck is a combination of many years. The previous owner had the truck for many years and used many years part to fix her. The VIN for the engine/frame is from 1962, but the cab is a 64. So you are probably right on the money on the reason why this switch is in there. And it is a two speed motor.
I guess I should ask, would the incorrect switch be the reason why this one is cutting in and out? I was thinking about picking up the Painless universal switch #910-64056 from Speedway since I couldn't match the switch (to my made up number). Or should I try to find the correct C1TF-17A553-C?
Old Oct 7, 2011 | 01:30 PM
Broomfieldbum's Avatar
Broomfieldbum
I went a step further than Stephens, and put a delay switch, module, and motor from a 79 Lariat, and now I have delay wipers with stock look.
Old Oct 7, 2011 | 03:16 PM
NumberDummy
Thanks Bill!
The switch is history, but I dunno if the C3TZ-17A553-E switch is causing the problem...because how long did it work before failing?
If the cab is from a 1964, I would assume the motor is too, which means the C3TZ-17A553-E switch is correct....there are 4 available NOS.
There are 11 of the C1TF-17A553-C switches available NOS
You don't have to look, because I already have, will list the sources for one or both of the switches if you're interested.
Old Oct 7, 2011 | 05:10 PM
Tony_C's Avatar
Tony_C
The previous owner said it was an existing problem, so I really don't know how long this has been happening. When first I picked the truck to drive her home, he said the wiper switch was bad and that I would have to turn it off and on to get it to work again.
As for the history of the truck, he had it for almost 30 years, and did tell me that the cab was from a 64 dump on the original 62 frame/engine. I know he used many parts from many years, and heck, I still can't even find a fuse box on her yet. So I'm not sure which switch to use, but would definitely know where I could pick up one that would work.
Old Oct 8, 2011 | 02:34 AM
NumberDummy
The fuse box is mounted to the headlamp switch.
You want the switch that would be correct for the 1964 cab: C3TZ-17A553-E?
Old Oct 8, 2011 | 05:41 PM
Tony_C's Avatar
Tony_C
Yes, the 64 switch would make sense, so lets see whats out there on that one.
And thanks for the heads up on the fuse box, I will check out that location.
Old Oct 9, 2011 | 05:48 AM
NumberDummy
C3TZ-17A553-E Last MSRP: $38.73 / Dealer net cost: $17.43.
ANTIQUE AUTO SUPPLY in Arlington TX has ONE = 817-275-2381.
MILLER OBSOLETE PARTS in Binghamton NY has ONE = 607-722-5371.
NOS PARTS SOURCE in Lenexa KS has ONE = 913-220-5746.
HIGH BUCK! BOB ALLEN FORD in Overland Park KS has ONE = 800-676-0675.
Old Oct 9, 2011 | 11:15 AM
Tony_C's Avatar
Tony_C
Thanks Bill!
lindascott
1961 - 1963 F100 Unibody
Aug 2, 2018 08:58 AM
John32369
May 14, 2018 10:38 PM
ihcc104
Jun 16, 2017 11:38 AM
tonkaman3
32
Aug 22, 2016 08:38 PM
ocbp1981
Oct 28, 2011 04:33 AM
