Mitre saw bench question...
Old Oct 15, 2011 | 02:26 PM
Sterling Archer's Avatar
Sterling Archer
I went ahead and bought a Skil bench (similar to the ones posted). It works well. I cut a couple of 4x4's this afternoon. After weighing spending the extra ~$60 on the bench vs. wasting an entire afternoon building a bench, I just opted to buy one.
This is fine for a hobbyist. If I was going to be taking on more projects, I'd just build a nice/sturdy 2x4 bench.
Old Oct 15, 2011 | 09:13 PM
oldgoat49's Avatar
oldgoat49
Even the Skil or other lower priced stands are worth it even for a homeowner. I've got one of my saws on a piece of plywood so that I can take it where I need it and just clamp it to some table and go on. However having a stand makes it a lot easier and pleasant to do a project and probably will make you more inclined to doing more than if you had to jury rig everything. The HF stand if it is anything like the stand I bought with my Sears radial arm saw might not be a good investment. Just wasn't very sturdy to me.
Old Oct 15, 2011 | 11:37 PM
4dfan's Avatar
4dfan
I have a table I made from leftover plywood and 2x4s, held up with saw-horses.
Not very fancy, but I never have to worry about ruining it. If I'm cutting siding, I can make myself a guide for the skilsaw. When I need the chop saw, I can screw it down to the table, and nail down some scrap pieces of lumber to hold the boards level while I'm cutting. It's also handy to bring on jobs because you can stand on it, or keep next to you when you're working under the hood of your truck.
I don't have a lot of room, so when I'm not using it, I put the sawhorses and the tools on the shelf, and lean the table top up against a wall.
Old Oct 16, 2011 | 07:10 PM
Sterling Archer
Yeah...I'm sure that wouldn't have been worth the money. It was 3" shorter than this one. By the time you bought the additional rollers/support, you'd only "save" ~$30. That and nothing HF sells has much of a warranty.
Old Oct 16, 2011 | 07:21 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
I have the Hitachi 12" bevel miter saw, and it's a heavy little bugger. I just set it on the table saw when I want to use it, and set it on the floor if I need the table saw. The table saw is on casters, so I usually roll it outside to use, with or without the miter saw....
Old Oct 16, 2011 | 07:53 PM
lenny1carl's Avatar
lenny1carl
I kind of like that rig....and I'm tighter than a ducksass
Old Oct 17, 2011 | 10:01 AM
Sterling Archer
Yeah...that's where I am at the moment too. I think it's a good buy for the money though. I just balked (initially) at the thought of spending $100 on a bench.
Another thing....if anyone is considering getting a mitre saw. Go with a 12" (if you've got the dough). That I could tell after less than ten cuts. I had to tilt the outer edge of the board up to finish a cut (2x6). Will a 10" get most homeowner jobs done? Yes. (I used a borrowed 10" to do my floor) However, a 12" will make some jobs quicker/easier.
Old Oct 17, 2011 | 11:13 AM
Eatonpcat's Avatar
Eatonpcat
Good advice on the 12"...I also got a 10" and although it is usually big enough, there are times I wished I had gotten the 12".
Old Oct 17, 2011 | 11:30 AM
bpounds's Avatar
bpounds
Do you guys not like sliders? Is that because of cost, or less precision?
Old Oct 17, 2011 | 12:17 PM
Sterling Archer
Cost. I didn't see a bench in the ~$100 range that had rollers.
Edit: Rollers would be nice...especially when you're trying to nudge a heavy piece of wood (i.e. 4x4) over ~1/4". I kept moving it 1/2"+ at a time back and forth. That was a bit annoying. lol.
Old Oct 17, 2011 | 12:28 PM
bpounds's Avatar
bpounds
I was referring to sliding compound miter saws, for increased capacity.
Old Oct 17, 2011 | 01:43 PM
Sterling Archer
Huh. I didn't know they existed. Something tells me I'm not the only one. lol.
Old Oct 17, 2011 | 02:48 PM
  #28
jroehl's Avatar
jroehl
To move a workpiece a small amount, I don't try to push or pull it. I swing one end out and push it back to the fence, almost "willing" it over the amount I want. Takes a little practice to get the feel for it, but it works well.
Jason
Old Oct 17, 2011 | 02:49 PM
  #29
bpounds's Avatar
bpounds
Oh yes, but considerably more expensive.
Old Oct 17, 2011 | 03:26 PM
  #30
Sterling Archer
Jason
Jason,
Thanks for the pointer. I'll give that a try tomorrow. I'm working on putting in a playground for my kids in the backyard from hell (VERY uneven ground where it's going in).
John
Oh....that's nice.
