Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Dies after not being driven for a while
Old Oct 5, 2011 | 03:14 PM
Don1959's Avatar
Don1959
I have a 1994 Ford F700 Bucket Truck with the 5.9 Cummins. If I drive it at lest once a week it does fine and does not die. But If i don't use it for a 2 or 3 weeks, when I start it (starts great) it will run for about 8 to 10 minutes and dies. It will start back up but is hard to start with throttle to the floor. Some times it will stay running after that or you have to do that 2 or 3 times, then usually after that it will continue to run. Any advice or help would be appreciated.
Old Oct 5, 2011 | 03:40 PM
jc8825's Avatar
jc8825
Your best bet would be to post in the 'Large Truck' forum. Or even a Dodge forum as those 5.9s were put in Ram trucks.
Old Oct 5, 2011 | 04:14 PM
powerstroke72's Avatar
powerstroke72
Moved to the Large Truck forum.
Old Oct 5, 2011 | 08:41 PM
awhtx's Avatar
awhtx
It sounds to me like it is getting air in the fuel system when it sits. If it has a large screw-on fuel filter remove the filter and see if it is full of fuel before you start it the next time it has sat for a couple of weeks.
Old Oct 5, 2011 | 08:50 PM
80broncoman's Avatar
80broncoman
You are either getting air in or not enough fuel to the injection pump.
You have the screw on filter and then a screen in a cup next to that and i think there is a screen in the tank,....although I'm not 100% sure about the screen in the tank.
Run till it quits and then remove the screw on filter. If it is COMPLTY full of fuel you most like have enough fuel. No matter what I'd stick a new on on it anyway.
Old Oct 8, 2011 | 12:41 AM
rummur s.c.'s Avatar
rummur s.c.
Whats the weather like around there?
I had an air compressor that would only run if it was put in the shop at nights. Found out the fuel tank had a crack around the fill cap. Im in washington state so its usually wet. Whenever the rain would fall the fuel tank would fill with water. The engine would start and run for a couple minutes then die once the water got into the system.
Probably air though.. Get your vacuum gauge and start checking the suction side of the fuel system.
cabloom300
Jan 10, 2018 08:02 PM
schpoogie
Aug 29, 2015 08:34 PM
trevorrules
37
Sep 3, 2014 02:49 PM
dancraig
26
Aug 17, 2012 10:29 PM
wesayso
Escape & Escape Hybrid
Mar 19, 2011 11:23 PM
