Sponsored by: Real Truck
Plus-Sized Wipers
Old Oct 5, 2011 | 07:35 PM
  #31
acf6's Avatar
acf6
Originally Posted by dchamberlain
Unfortunately, age does tend weaken a guys squirter.
Old Oct 5, 2011 | 07:53 PM
  #32
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Originally Posted by acf6
thats funny you post that, mine just started becoming very weak also
Maybe I should add a filter. I'm thinking a 1 micron spin on filter for the washer fluid should do the trick.
Old Oct 5, 2011 | 08:10 PM
  #33
Quad Racer's Avatar
Quad Racer
Not sure a filter alone would work. You may want to run a reverse osmosis set up to keep the fluid properly cleaned. haha
Old Oct 5, 2011 | 08:16 PM
  #34
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Double post
  #35
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I also planed on a bypass filter and have a blackstone kit I'll fill with washer fluid for testing.
Old Oct 5, 2011 | 08:35 PM
  #36
Pili's Avatar
Pili
I know lots about rain being in FL. The rain X washer fluid works good and helps even with heavy downpours. I also change my blades twice a year as they start streaking after 7 months. When the sprayer clogs just use a sewing needle.
Old Oct 5, 2011 | 10:08 PM
  #37
hotroddsl's Avatar
hotroddsl
I can see it now! Washer fluid filter installation thread! W/ PICS:
Jim & fat sick with the flu Monty
Old Oct 5, 2011 | 10:10 PM
  #38
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I will keep everyone posted!
Sorry to hear about the flu Jim/Monty. I am just getting over one myself.
Old Oct 5, 2011 | 10:12 PM
  #39
Pili's Avatar
Pili
I would put money on a diesel guy doing it first
Old Oct 5, 2011 | 10:15 PM
  #40
A/Ox4's Avatar
A/Ox4
9 ECHO 1
We filter everything
Old Oct 5, 2011 | 11:07 PM
  #41
hotroddsl's Avatar
hotroddsl
Except exhaust!
Jim & fat feeling a bit better Monty
Old Oct 5, 2011 | 11:08 PM
  #42
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Except exhaust!
*ahem*
DEF.
Cat.
Luckily, WE dont have to.
But the new diesel guys do filter exhaust.
However, in a perfect world, I would like to see all vehicles, cars and trucks, running on diesel and using DEF. I believe in a clean environment and diesel. Its a big pill to swallow but thats the way I want it to be. The new diesel trucks using DEF emit less toxic gasses than the most up to date gasoline vehicles*.
* Citation needed
Old Oct 6, 2011 | 12:17 AM
  #43
hotroddsl's Avatar
hotroddsl
Have my tuning set up for NO SMOKE! When I see a truck dumping clouds of black garbage my thoughts always go to that guy needs a bigger turbo
Jim & fat clean burning Monty!
Old Oct 6, 2011 | 12:19 AM
  #44
A/Ox4's Avatar
A/Ox4
9 ECHO 1
And to think. This thread was about wiper size...
Old Oct 6, 2011 | 02:09 AM
  #45
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
My driver side squirter has become weak. Is this common?
I just fixed mine the other day. It's easy, but tedious. just have to pull the drivers cowl off (3-4 screws, 4 push holder things)...then use a garden hose sprayer nozzle to backflush it.
before was a slight "dribble"....perfect spray pattern now
