Sponsored by: Real Truck
99' drive shaft replacemt
Old Oct 5, 2011 | 09:33 AM
SteveO.'s Avatar
SteveO.
Hello FTE,
I have 99' (feb) f250 SD 4WD with 135,000 miles. I've had a slight vibration that seemed to get a little worse over the last 6 months. Had the tires re-balanced and it seemed to help. Now when I hit 55 mph and above I get the vibration. Took into the local stealer, I mean dealer, and they said the drive shaft is bent and want $750+ to replace it!!
Not sure how it could of bent. I use the truck to pull my 5th wheel otherwise it's a weekend driver.
My question is, should I just get one from a Junk Yard, Or order one from somewhere else?
Any other possiblities of the vibration? could a balancing weight rusted off and I just need it re-balanced?
Tips, pointers, suggestions would be appreciated!!
Thanks!
Old Oct 5, 2011 | 12:18 PM
Kajtek1's Avatar
Kajtek1
I would get the second opinion or at least check it yourself. Bend drive-shaft would heave some visible damage on it, or carpenters level edge or other straight piece of metal can confirm the shaft damage.
Old Oct 5, 2011 | 10:03 PM
01F-250/04ex's Avatar
01F-250/04ex
If you have a local driveline shop I would pull it out and take it there. I just had a truck driveline completely rebuilt, everything new except tube, took 1.5 hrs to get it back. It was from a truck so much bigger and more expensive, $1125, but all is good. The only way it would get bent, IMHO, is if it got hit or someone did a bad u-joint install like hitting tube or using press.
Old Oct 6, 2011 | 07:38 AM
SteveO.'s Avatar
SteveO.
BS
Yeah,
I'm not buying the bent drive shaft thing.....
It's a weekend driver. I don't go off roading or anything. I can't imagine how if would of bent.
They didn't even put a wrench on it, the tech could just tell by driving it. ......and I have to pay the $85 diagnostic fee for test drive.
gonna call some junk yards today to see if I can find a used one. There is a driveline shop not too far away. I'll give them a call as well.
Thanks for the feedback!
ncl
Jul 22, 2014 06:15 AM
96_F250_Deezal
Sep 5, 2013 07:31 AM
mgage06
Mar 13, 2012 07:00 PM
fordman1090
Apr 14, 2010 09:05 PM
fairlaniac
1983 - 2012 Ranger & B-Series
Apr 1, 2008 06:43 AM
