6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
2008 6.4 setting code P0087 under load, stock engine
Old Oct 4, 2011 | 01:14 PM
snopro29's Avatar
snopro29
I have a 08 6.4 power stroke and when its loaded pulling a hill it will set a P0087 low rail pressure code and then it derates the power until the code clears of you turn it off for a few minutes it's only does it loaded so any help would be great Thanks Dave It has 124000 on it
Old Oct 4, 2011 | 01:23 PM
senix's Avatar
senix
Look for your HPFP as an issue. Check and change your fuel filters. Ensure all is clean. Shine a light in the fuel bowl and check for rust or metal contamination.
Might want to check your extended warranty.
Keep reciepts for your maintance.
Old Oct 4, 2011 | 01:39 PM
snopro29's Avatar
snopro29
the filters are new and they get changed on a regular maintence schedule and all looks clean i was thinking of the hpfp and there is a tsb for a code P0088 to replace the pump cause it all test good. i am looking at the cat and the DPF cause it is going into regen alot i test drove it 20 miles and came back to shop and checked the recored data the desired backpressue was about 30 psi lower than the actual filled it up with fuel and on the next test drive it regened again so im thinking that the exhaust might be the problem, and taking the exaust parts out to test drive will set a code i believe?
Old Oct 4, 2011 | 01:53 PM
senix's Avatar
senix
Yes if the parts are missing with out tuning the truck to shut off the regen it will cause problems.
Old Oct 4, 2011 | 02:03 PM
snopro29's Avatar
snopro29
that's what i was thinking does someone make a tuner for these so you can take out the DPF and CAT i have been looking but no real hard? Thanks for the info i will post my findings when i get this fixed
Old Oct 4, 2011 | 02:18 PM
senix's Avatar
senix
Spartan, H&S, DPF-R, SCT and probably a few more.
Old Oct 4, 2011 | 08:04 PM
cheezit's Avatar
cheezit
if rail pressure is low and your going in to regens alot odds are its a result of the extra soot load from the p0087 vs an issue with the pipes reaking havoc with the fuel system.
think about it
Old Oct 5, 2011 | 08:58 AM
Tom's Avatar
Tom
The OP had another thread in the SD forum about the same issue that was moved down here. I removed it, as there were no useful replies there and it would have just been confusing!
Secondly, is the truck completely stock right now?
Old Oct 5, 2011 | 11:02 AM
snopro29's Avatar
snopro29
I don't see in our scanner where the pid for the high pressure fuel,in our scanner its not a ford new gen or VCM its aftermarket we have an older new gen plus but it will only go to 2005, Yes the truck is all stock
Old Oct 5, 2011 | 05:55 PM
cheezit's Avatar
cheezit
pids are vcv pcv and frp.
Old Dec 19, 2011 | 02:08 PM
snopro29's Avatar
snopro29
we had this truck at the fore drealer and they told us to replace # 2 injector and when that didnt fix it the said to replace high pressure fuel pump and that didnt fix the problem the repair that fixed it was an updated flash of the ecm
Old Feb 24, 2021 | 12:27 AM
danny vang's Avatar
danny vang
were you able to get your trucks problem fixed? I'm currently having the same issue as well with my truck. Can seem to find any kind of solid info on it on what's really going on. Any help would greatly be appreciated. Thanks
Old Feb 24, 2021 | 05:06 AM
senix's Avatar
senix
The fix will be a new HPFP. The VCV that is attached to the HPFP is bad.
minnieub
6.7L Power Stroke Diesel
Jun 18, 2018 03:48 PM
tucker83014
Jun 16, 2018 04:02 PM
LeoH
May 29, 2014 12:09 PM
markt1993
May 24, 2009 11:44 AM
