Airfilter (Oil Bath) Assembly
Old Oct 4, 2011 | 06:54 AM
BeerKnurd's Avatar
BeerKnurd
I have a 1962 F100 with a 223 and single barrel carb. I was wondering if anyone could provide a photo and details on how the oil bath is attached to the carb. My carb is missing the screw assembly that connects them both. Any work arounds would be greatly appreciated too!
Old Oct 4, 2011 | 10:20 AM
63' f100's Avatar
63' f100
Its just bolted on. You can see a hole in the center on the top section of the filter. That is where the bolt goes on, then there is a nut that screws on that you can twist with you fingers. The bolt should come through the center of the carb and is about 6-8'' long if i remember correctly. Its pretty obvious, so if its not there you are missing it.
Old Oct 4, 2011 | 01:24 PM
BeerKnurd's Avatar
BeerKnurd
Thanks for your reply 63' f100! It seems that my 1904 Holley one barrel has two screw holes on opposite sides of the "throttle" instead of a normal center post as most carbs have. Thinking the bracket may have looked like a lamp shade bracket to screw down the air cleaner. Does this sound normal?
Old Oct 4, 2011 | 01:49 PM
429unibody's Avatar
429unibody
Is this what your looking for?
Old Oct 4, 2011 | 03:23 PM
BeerKnurd's Avatar
BeerKnurd
Thats it! Thanks for the picture. Now I know what to look for. Wonder if I can retro fit something.
Old Oct 5, 2011 | 05:28 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by BeerKnurd
My Holley has two screw holes on either side of the carburetor body, just below the throat. Thinking the bracket may have looked like a lamp shade bracket.
Correctamundo.
Originally Posted by 429unibody
Is this what you're looking for?
That's it.
(sigh) No it is not, open your peepers and take a look-see. Does this look like a lamp shade bracket? Where are the two holes on this adapter that mount it to the carburetor? No see um.
There is no way...none...that this adapter will work on your carburetor.
C3AZ-9B672-A .. Carburetor to Air Cleaner Mounting Bracket / Obsolete / 41 available NOS from Ford Dealers/obsolete parts vendors.
Looks just like a \_/ lamp shade bracket. Has two legs with holes in them for the two pins that retain it to the carb.
The center has a threaded hole. A threaded stud of the correct length will be required, threads into the bracket, then passes thru the air cleaner. A wing nut retains it.
2) C3AZ-9C631-A .. Air Cleaner Retaining Pin-Use with C3AZ-9B672-A adapter / Obsolete / 2 of these pins are available NOS.
This bracket and its two retaining pins were used on a gazillion 1960's I-6 Passenger Cars, F100/350's, Bronco's and Econolines.
Old Oct 5, 2011 | 07:06 AM
BeerKnurd's Avatar
BeerKnurd
I assumed it was like a lamp shade but wasnt sure. Thanks for the info.
Old Oct 5, 2011 | 10:15 AM
429unibody's Avatar
429unibody
Well shiver me timbers,this is what came off of my 64!
Old Oct 5, 2011 | 10:39 AM
429unibody's Avatar
429unibody
Ok I just took these photos of the motor in my 63
After cleaning in my tank
Old Oct 5, 2011 | 10:45 AM
429unibody's Avatar
429unibody
I checked this mount on all the carbs on my trucks and it's a little ******* it don't fit any of them .Someone must have just placed it on one of the trucks before I bought it, Good thing we have experts on this forum to correct us wanna bees
brobrad
May 21, 2013 11:42 AM
raytasch
WTB - Parts & other
Feb 6, 2013 05:59 PM
mybrownie
Apr 3, 2009 07:36 AM
mopakel
Jul 3, 2008 02:29 PM
hotrodford_88
Jan 25, 2001 07:27 PM
