Diesel additive
Old Oct 3, 2011 | 09:03 PM
upnorthman's Avatar
upnorthman
Diesel additive
I have a 2001 7.3 in my Ex. I live in WI and travel north alot for snowmobiling. I have been noticing alot of the diesel guys are switching to Amzoil additive..summer and winter formula..from Power Service?? They are happier with it..milage..higher cetane level. Anyone else have any experience with Amzoil??? Thanks guys..
Old Oct 3, 2011 | 09:23 PM
Tailgate77478's Avatar
Tailgate77478
I run Amsoil fluids in my crankcase, tranny, and rear differential in HERS (below). I believe synthetics are better than standard dino oil / fluids for longevity and performance. In HIS, I run Amsoil in the rear differential, Schaeffer's in the tranny (Brian from BTS wants his tranny using Schaeffer's, so I say "Yes, Sir!!!"), and Shell Rotella T (regular dino oil) in the crankcase.
When it comes to oil in the crankcase, while I believe synthetics are better...I think filtration is much more important than whether you're using dinosaur oil or bar stock synthetic. Frankly, I believe Amsoil to be far overpriced, even though I still use it in that one truck religiously. Get a good bypass filtration system on your truck, and if you also want to use synthetic later, that's great. It's looking more and more likely I am going to switch to Rotella Synthetic in the crankcases of both trucks in the near future, after 9 years of Amsoil.
If you are talking about the Amsoil fuel additive...it is "OK," but the OptiLube products have tested MUCH higher, and for a lot less per tank. I used the Amsoil diesel additive for about 8 tank fulls, and felt like I wasted my money. I'm sure it was better than not using it, but B20 biodiesel would have been far superior.
Franko72 posted the chart of fuel additives on this thread...he's the 2nd or 3rd post:
https://www.ford-trucks.com/forums/1...l-in-fuel.html
Old Oct 3, 2011 | 10:45 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I run Diesel Kleen (Grey jug) in a tank every once in a while.
Old Oct 4, 2011 | 01:01 AM
dn29626's Avatar
dn29626
Seafoam is also a good choice.
Old Oct 4, 2011 | 02:09 AM
mndiesel's Avatar
mndiesel
Schaeffers is what I use.....
Old Oct 4, 2011 | 02:43 AM
Skip1970's Avatar
Skip1970
if i switched to heating oil #1 do you think i would need the additive still ?
Old Oct 4, 2011 | 07:42 AM
joeyd61's Avatar
joeyd61
i use the Opti-Libe XPD and my rig really likes the stuff...
Old Oct 4, 2011 | 09:59 PM
upnorthman's Avatar
upnorthman
looks like frankos report says Amzoil is almost 3 times better tha Power Service..and the opti is really expensive...
Old Oct 5, 2011 | 05:26 PM
Tailgate77478
OptiLube Summer Blend...dirt cheap. T here are three different blends of OptiLube.
Old Oct 5, 2011 | 07:16 PM
ToMang07's Avatar
ToMang07
I run the Power Service "Diesel Kleen" White Bottle in Winter, Grey in Summer.
I also add about 1oz/gallon of (ashless) 2-cycle engine oil. Keeps the old girl happy!
Old Oct 5, 2011 | 08:58 PM
powerstroker100's Avatar
powerstroker100
I use Howes additive
Old Oct 6, 2011 | 12:43 AM
BadDogKuzz's Avatar
BadDogKuzz
I use Diesel Kleen or Blue Marble 2stroke 600:1 and I use XDP Polar in the winter. And I think I am going try some cheap 2stroke next and try 200:1
Old Oct 10, 2011 | 10:04 AM
aklim's Avatar
aklim
If you are into the snowmobiling thing, it is going to be cold. Might be nice to come back to the truck after a freezing ride and have it start easier. I would use 5W40 Shell Rotella which is diesel rated and flows better. When I am in a risky situation weather wise, I dump some anti-gel before and let it work thru the system and be happy when it starts up nicely.
Other than that, I haven't personally seen any of the snake oils give anything more than a lightening of the wallet. Used to drive a diesel car 200 miles a day and none of them made much of a difference when cruising at 80 and have a little city driving.
PEI
Oct 26, 2010 01:45 PM
lancer
Oil & Lubrication
Nov 2, 2004 11:13 AM
rusty70f100
Oil & Lubrication
Jun 19, 2004 04:34 PM
MJW
Jan 16, 2004 11:10 PM
Luker
Oil & Lubrication
Jul 8, 2003 01:22 PM
