CAT DELETE
Old Oct 4, 2011 | 07:05 AM
Edgethis's Avatar
Edgethis
Originally Posted by xc4jokestomper
If you go with true duals do you end up losing your egr?
I may have to check out the pacesetter too but i was pretty set on a pair of hookers..
...lol. Ok, you can have a bung welded on to most any brand header, but the pacesetter's have it on there from the factory.
As stated before true duals will reduce your backpressure and hurt your low end, on top of that getting rid of the EGR will make you lose a few MPG. With all that, I figure I'd just as well go ahead and keep the EGR and go with pacesetter anda good Y-pipe.
Old Oct 4, 2011 | 07:24 AM
xc4jokestomper's Avatar
xc4jokestomper
ahhhh i see. does anyone have anything to say about the fitment of the hooker headers?
Old Oct 4, 2011 | 07:39 AM
IowanStraight6's Avatar
IowanStraight6
Go on rpm outlet they have o2 simulators gettin a pair for my 96 and dads 96 due to pluged cats and 100 bucks for two sensors is better than the price of two new cats just find someone you can sell your other one to
Old Oct 4, 2011 | 09:34 AM
Conanski's Avatar
Conanski
Duals or single got nothing to do with EGR, on the 5.8 it just comes down to whether the headers have an EGR port or not and even if they don't adding one isn't a big deal, and on the 5.0 it's totally irrelevent because the EGR doesn't connect to the exhaust.
Old Oct 4, 2011 | 09:37 AM
Conanski's Avatar
Conanski
You can't replace the front O2 sensors with simulators, it's the only feedback the computer gets on the A/F ratio the engine is actually producing. This will also set codes and result in high fuel consumption.
Old Oct 4, 2011 | 09:40 AM
Kemicalburns's Avatar
Kemicalburns
tricking the computer is lame anyhow. get some high flow cats in there. your talking $60/cat
you probably need to get your pipe upgraded anyhow if its stock. take that time to go from 2 cats to 1 hi flow unit. we all breath better, performance is increased and the efi system is happy also.
Old Oct 4, 2011 | 09:48 AM
IowanStraight6
I'm talkin about the third one between the two cats
Old Oct 4, 2011 | 09:59 AM
deljac's Avatar
deljac
so what your saying is keep the 1st O2 sensor and get simulators for the other 2. i will hafta check on a set of them
Old Oct 4, 2011 | 12:46 PM
Kemicalburns
no, you must keep the first 2 sensors. they should be on either side of the current y pipe near the collector. you should then have 1 cat and the 3rd o2 sensor and another cat after that.
you can put a hi flow cat before the last o2 and then no cat after.
the computer reads from either bank right/left and makes adjustments then confirming those with the last o2. obd-II is complicated in some ways but very efficient for this reason.
BULLETPROOF4.9
Exhaust Systems
Nov 14, 2009 06:09 PM
mike2112
Exhaust Systems
Aug 8, 2006 08:28 PM
4.9inline6
Nov 13, 2005 10:29 AM
turboguy
Exhaust Systems
Mar 11, 2005 06:40 PM
technoman26
Exhaust Systems
Feb 1, 2005 03:43 PM
