What's this?
Old Oct 2, 2011 | 09:08 PM
ct50f1's Avatar
ct50f1
What's this?
When I got my truck it had a short band of metal attached to the engine (6 cylinder - 226) where the right front engine mount attaches to the engine. Its about 1/2" wide and about 3 1/2" long, although the end looks like it was broken off.
I'm assuming it's just something added by the P.O. that doesn't belong there but before I throw it away I thought I better check and see if it's actually something that belongs there. Does anyone think it's something that was put there by Ford?
Old Oct 2, 2011 | 09:44 PM
gdgerland's Avatar
gdgerland
Dan, my '50/226 does not have that piece installed, but mine is missing the heat shield (baffle) that was over the exhaust manifold. If you look at the shop manual, Fig. 6 Pg. 41, you will see the baffle p/n 9437. That looks like the lower attachment point for this unit.
Gil
Old Oct 2, 2011 | 10:07 PM
brain75's Avatar
brain75
I have a very close to original truck, 1948 f1, 226 and I do not remember seeing that. I've not had the sheetmetal off so haven't really really looked there. I have looked for the frame serial, and I have replace the fuel lines... all in that area. If you want I will double check next time I am out (this Sat - I only get to the shop on weekends).
All that said, I do NOT think that is original.
Old Oct 2, 2011 | 10:18 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Gil's got it, you can barely see it in this snip from the manual.
mblayton's Avatar
mblayton
Looks like a i.d. tag, but appears there are no numbers on it.
Old Oct 3, 2011 | 06:23 AM
ct50f1's Avatar
ct50f1
I hadn't thought of that. Numbers could have been on the end that appears to have broken off.
Old Oct 3, 2011 | 06:34 AM
ct50f1's Avatar
ct50f1
I read the last post (from mblayton) before I saw the responses from you and Ross. Looks like you guys figured it out. Thanks. I've never seen an engine with that baffle installed.
Old Oct 3, 2011 | 10:28 AM
52 Merc's Avatar
52 Merc
If anyone needs/wants one of those heat shields, feel free to PM me. I've got a couple.
sammywayne23
18
Dec 31, 2021 11:09 AM
Lukes07vette
Jun 16, 2019 07:17 PM
suprchunk
23
May 1, 2018 06:26 PM
fixnair
Mar 12, 2010 09:34 AM
