no start now?
no start now?
I still have the steering wheel off and just removed and rebuilt the PS box..bolted it all back up fill with fluid and when I went to fire it - nothing. it rolls over and I can hear the fuel pump. I did blow a fuse when working on the column but thats been replaced.. did I blow a fusable link? does the steering wheel need to be on? help this sucks, thanks
1988 e-350 460 c/w
<!-- / message -->
1988 e-350 460 c/w
<!-- / message -->
There are some fuseable links in the bunch of wires that bolt to the starter relay on the pass side inner fender. You will have two fuel pumps, one in the tank and a high pressure one on the frame rail. You should hear both running for about 2 secs when you turn the key to on (hard to hear the intank one unless near it when the key is switched).
Hopefully one of the experts will give an opinion soon.
Bluesrx
1997-2006 Expedition & Navigator
03-03-2009 04:11 PM
