switches not working
Old Oct 2, 2011 | 05:53 PM
Apollosgrill's Avatar
Apollosgrill
Need help, I have a 1997 E450 shuttle bus that I converted to a food truck Today I went out and cranked it up and went to open the side door but it wouldnt open then I tried the fan switch none of the switches work the gauge for the battery and air suspension dont work either is there a master fuse or wire that may be loose. Generally when I crank it a buzzer comes on for the air leveling till it builds up 60psi even that buzzer doesnt go off.
I would appreciate any advice
thanks
Old Oct 2, 2011 | 10:53 PM
oldbird1965's Avatar
oldbird1965
Check all your fuses.
Old Oct 3, 2011 | 12:53 PM
Apollosgrill
Still need help, I checked the fuses under the hood and also upfront in the cab
thanks
Old Oct 3, 2011 | 01:05 PM
Hussler's Avatar
Hussler
Does the bus start and run?
Generally on conversions a separate circuit breaker is used to run the back area electrical. Is there a separate battery in the back or did you tie everything to the main batteries? More information is needed to help on this one.
Old Oct 3, 2011 | 04:56 PM
Apollosgrill
thanks Jim,
found the problem, on the stepup as you get into the drivers seat there is a switch that cuts power to all of the inside of the bus, but still allows the bus to crank. My kids must have hit it the other night. Thanks again
sunbelt57
Modular V8 (4.6L, 5.4L)
May 3, 2019 03:49 PM
siuhortguy
May 5, 2016 05:35 AM
NorthCarolinaExpy
Apr 25, 2009 11:15 AM
jared66
1997 - 2003 F150
Dec 23, 2007 09:33 PM
BK50
Electrical Systems/Wiring
Sep 27, 2007 09:39 AM
