Wiring Garage Outlets
I am only getting power to one of the 6 outlets I ran. I ran the plugs in a series. I tapped into constant power from an existing outlet and ran it into a junction box.
I tapped into the black 3 wire wire. The wire going out the back is going down to the plug to give the constant power.
Down at the flip switch, I have one ground/black/white and then the same wire going up into the ceiling to the first outlet, its getting power to just one of the double outlets and that is it.
The one with a plug in it is getting power but the other isnt.
This is where its going down to the switch
This is one of the outlets
This is the first outlet in the series
The middle one in the series
The last one
We had it wired to the switch but only got power to one of the double outlets, the first one in the series. When id hit the switch to turn the light off it was kicking the breaker.
Are you connecting black to white, to black to white, or black to black and white to white ??????
First things first.
I need to stress that if you don't know what you are doing in an electrical circuit - STOP all work, and call a QUALIFIED electrician!!
The outlets should not be in series. (To me, connected in series is negative to positive, positive to negative, etc., etc., etc.)
Connect all of the black wires together.
Connect all of the white wires together.
Also, for a 'standard' SPST (wall) switch, the BLACK (Hot) wire connects to one side of the switch, and the outgoing BLACK wire (to the outlet or light fixture) is on the other connector.
The WHITE wires are connected together with a wire nut behind the switch.
The bare or ground wire connects to the switch and also continues through the 'run'.
NEVER connect black to white on a 'standard' 2 wire w/ground.
Also, use the correct sized wire nuts on each wire!
In your outlet boxes you should have 'wires in' connected to 'wires out' twisted together and have a 'pigtail' going from each wirenut, to the outlet in that box.
OR, you could have black wires connected to the GOLD connectors on the back of the outlet, and the white wires connected to the SILVER connectors on the back of the outlet.
NEVER use the 'strip and push in' connectors on the back of the outlet. To me, that is not very secure. (I've also seen wires connected this way come out and cause short circuits.
Again, I must stress - if you don't know what you are doing in an electrical circuit - STOP all work, and call an electrician!!
ETA: From the way it looks, you don't have enough of the sheath (outer insulator) cut back. You should have approximately four to six inches (4-6") of the individual conductors (black and white wires) to work with.
It sounds as though you are going to have all outlets and light controlled by the switch.
I stress again. . . . if you don't know exactly what you are doing in an electrical circuit, contact a qualified electrician.
I am wanting to get the power for the new outlets from the existing outlet.
(Note: You should calculate how many amps that circuit is drawing!)
When you come out of the first (existing) outlet, run wire to switch.
Connect (as I tried to state earlier) white to white and use wirenuts. The white wire is the "Common" or 'Neutral'.
Connect incoming black (hot) wire to the switch.
Connect the outgoing black (hot) wire to the other post on the switch.
Connect ground to ground and run a ground wire to the bottom 'post' (Ground post) on switch.
From there, the outgoing black and white wires connect to next outlet box and to that box's outgoing wires.
I always run a small 'pigtail' from the connected black wires to the 'hot side' of the outlet and a 'pigtail' from the connected white wires in each box.
(This makes it easier to replace an outlet that may/can go bad.)
To clarify, in each box, you should have three of each color connected with a wire nut.
Black in. Black out. Black pigtail to outlet.
White in. White out. White pigtail to outlet.
Bare wires twisted together with a pigtail to outlet.
Note: The white (common/neutral) wires should only be connected to each other and the SILVER connectors on the outlets.
The black (hot) wires connect to each other, to the GOLD (Brass) connector on the outlets, and to the switch. In this way, the 'hot' side of the outlets are removed/disconnected from the 'bus' in the circuit breaker/fuse box.
ETA: I must stress. . . for safety's sake (and your family's safety), If you don't know what you are doing, it's best for all, for you to contact a qualified, licensed electrician.
I've seen houses that have caught fire due to improper wiring.
You have power to the switch.
At the switch, white runs through, as does the ground as per a prior post. The black wire is switched.
At that point, if you are going to do 6 outlets, you either need to feed the switched power into a JB, then run 6 wire pairs out of it, or you need to wire the first outlet, then tap off it and go to the next one, and continue till you are done.
You say there is power at the first outlet. I take it the switch controls that power correctly? Are you tapping that one for the next outlet?
I can't really understand from the pics etc.
Also, the wire should be secured and not just hanging.
As per prior posts, beware if you are uncertain, and call an electrician if you can't figure it out after a fresh look.
115v-AC may seem mundane, but causes more fires and death than you would care to know.
Put up a good picture of the wiring on the first outlet that only has one plug with power.
I have them piggy backed into each other. Should I run a wire from each into a junction box or keep it the way I have it with one wired into the other and into the other?
