another oil psi problem help!!
Old Oct 2, 2011 | 05:17 PM
shooten roosters's Avatar
shooten roosters
ok i have a 79 f150 4x4 with a 400 in it mostley stock just has a rv cam and 4bbl intake. ok now when i was driving it home from work i looked at my aftermarket oil gauge and it was on 0 the truck was running fine well i drove it for a mile or 2 like that stoped at a gas station thinking it was time for a new motor. so i checked under the hood i was hoping the oil gauge line was pinched and i was full on oil, i was thinking that the oil pump took a crap cuz there was no loud knocking well i wanted to get it home so i got in fired it up and soon as i left the gas staion i looked and the oil psi was up at 20 psi again around 2500rpm any thoughts on what went wrong and why it started working again lol never had a truck fix its self before...should i just run it im working on getting a motor here in the next w
Old Oct 2, 2011 | 05:22 PM
montana_highboy's Avatar
montana_highboy
May of just been a momentary "glitch" with the gauge itself.
Old Oct 2, 2011 | 05:26 PM
shooten roosters
i hope so i will drive it in a few to see if it is going to knock if it wasnt the gauge any ideas what would have made it do that
Old Oct 2, 2011 | 05:32 PM
fmc400's Avatar
fmc400
MSEE
I'd just keep an eye on it, and see if it happens again. Something might have gotten caught in the filter and shutting the truck off let things settle out of the way. Who knows.
Old Oct 2, 2011 | 06:53 PM
jim collins's Avatar
jim collins
By aftermarket I assume a mechanical with a oil line. Possible air bubble in line ? I'm just guessing but watch it close.
Old Oct 2, 2011 | 07:46 PM
shooten roosters
yeah it has the little plastic oil line ill check it really good for kinks too
Old Oct 3, 2011 | 01:14 AM
Sleepy445FE's Avatar
Sleepy445FE
you should replace that plastic line with the copper one (10 bucks). The plastic are known to fail. Not that that's what happened just an fyi. I agree with the above possibilities.
Derrrrick
Oct 22, 2015 10:46 PM
beanhead6D5
Dec 15, 2009 12:21 AM
Ironman03R
36
Jun 4, 2009 08:13 AM
jdhudall
1997 - 2003 F150
13
Jan 3, 2008 04:07 PM
92Pony
Feb 21, 2005 09:51 PM
