Map sensor
Old Oct 2, 2011 | 01:11 PM
mjtpolice76's Avatar
mjtpolice76
Map sensor
I have a drop off in fuel mileage, black smoke when I hit the skinny pedal. Even if I don't hit it that hard. I checked for boost leaks today with the diesel site boost leak detector. Found one small leak, but it still holds pressure for about 30 seconds. I'm thinking it may be the MAP sensor, but how do I verify without a scan tool.
Old Oct 2, 2011 | 03:30 PM
mueckster's Avatar
mueckster
Have you cleaned your EBPS tube lately? I assume your not getting hard codes (SES light). Can you get it read for codes?
Old Oct 2, 2011 | 03:54 PM
mjtpolice76
Ebpv was replaced an cleaned. I do have a diablo sport tuner for my mustage can I use that to read the codes
Old Oct 2, 2011 | 04:05 PM
timmyboy76's Avatar
timmyboy76
Roland was suggesting the EPB tube. Its located in the front of motor, pass/ side of waterpump. Theres a sensor atop the tube as well. That tube goes from sensor to pass/ side manifold...
Welcome to guzzle's Exhaust Backpressure Sensor Cleaning Maintenance Web Page
Old Oct 2, 2011 | 04:44 PM
mjtpolice76
The tube was cleaned when I switched out the sensor
Old Oct 2, 2011 | 04:47 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Did you also make sure the manifold wasnt clogged?
Old Oct 2, 2011 | 05:06 PM
mjtpolice76
No, so stick a welding wire in there to see if it's plugged
Old Oct 2, 2011 | 05:07 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Pretty much. Chances are its not clogged, but its easy and free to check, and it is a possibility. Just poke something in the hole that the EBP tube goes in.
427 fordman
Feb 4, 2019 08:51 PM
Shane Wyatt
6.4L Power Stroke Diesel
Jan 19, 2017 09:42 PM
bcarless
Mar 5, 2016 08:25 PM
brownie83
19
Mar 4, 2011 03:19 AM
IDPisan
Oct 8, 2007 10:19 PM
