Tranny problem
Old Oct 2, 2011 | 12:05 PM
Jmudweiser's Avatar
Jmudweiser
Tranny problem
In the am when I put the truck in drive it doesn't go, rev and nothing! In a sec it will finally move. Fluid is good, tranny never has been hotter than 180. Now in combination w this in the am, sometimes even after driving all day if the truck sits for a couple hrs it does the same. Now and added symptom, I'll go to stop and the motor will lug down and die. If I go to 'n' and rev it's fine. All this started since I was pulling a trailer in the sand at Pismo and got stuck.
I was in drive and the trailer was a plow. Is this a failed torque converter? Not working at first then not unlocking when stoping the truck. I have ae now but not sure what to look at?
Old Oct 2, 2011 | 12:08 PM
kawcrasher's Avatar
kawcrasher
It sounds like TC issue.
Old Oct 2, 2011 | 12:18 PM
Jmudweiser's Avatar
Jmudweiser
I called John woods, when it was just a problem w no drive at first. He said Change the fluid and filter, check for anything in the pan. The. Call him and if needed he will send a crate to send the tranny back. I think there is only 8,000 miles on towmaster trans and billet triple disk tc.
Old Oct 2, 2011 | 02:20 PM
crazymut's Avatar
crazymut
Man that sucks. I also have tow master, 33k on it. So far no problems.
danman_83
Nov 4, 2015 12:32 PM
jejenkins417
Jun 17, 2011 10:58 AM
john410312
Mar 10, 2009 02:36 PM
FORD MEGA CAB!!!
13
Dec 17, 2008 07:29 AM
1978fordf250
Aug 20, 2005 06:57 PM
