Sponsored by: Auxito
03 5.4 troubles
Old Oct 2, 2011 | 11:41 AM
Moyerboy's Avatar
Moyerboy
03 5.4 troubles
I got a dumb question I dont play with gas engines alot I am a diesel mechanic and have a 03 F150 wih a running lean on banks 1 and 2 CEL would a cold air intake and throttle body spacer lead to a running lean CEL
Old Oct 2, 2011 | 03:57 PM
enriched&beyound's Avatar
enriched&beyound
A vacuum leak could...whether it is from the CAI or the throttle body spacer is unclear (BTW...the throttle body spacer isn't doing anything for your truck performance wise...it is making your wallet lighter).
the elbow on the rear of the throttle body housing for the PCV can deteriate and giving vacuum leak. vacuum leaks can be had most anywhere.
what have you done so far to correct this...& how long have you had this condition?
Old Oct 2, 2011 | 10:15 PM
Moyerboy's Avatar
Moyerboy
I havnt done anything yet to the truck it has had it for the past 3000 miles which have been accumulated over the past year. I know if its running lean im asking for trouble down the road. the truck only has 50000 on it thats why I dont understand why I would have a vacum leak.
Old Oct 2, 2011 | 10:34 PM
Bluegrass 7's Avatar
Bluegrass 7
Respectfully, are you kidding that you don't think there could/should be a leak on an 8 year old vehichle!
If the computer tells you by codes the results of excessive air after the air meter that is 'unaccounted for', you have to go with it as the truth.
Good luck.
Old Oct 3, 2011 | 07:15 PM
Moyerboy's Avatar
Moyerboy
well I wasnt thinking like that ill look at it this wkend thanks for the info
Old Oct 3, 2011 | 09:10 PM
steve(ill)'s Avatar
steve(ill)
above the drivers valve cover ( 2/3 of the way back from front) there are two vacuum hoses close to the exhaust manifold. like 3/16 or 1/4 ID... They get old and crack fro the heat. Swell and break at one end.. you might pull them off and check- replace.
Old Oct 3, 2011 | 10:07 PM
Moyerboy's Avatar
Moyerboy
ok ill look there to thanks
Old Oct 13, 2011 | 07:44 PM
Moyerboy's Avatar
Moyerboy
ok i tried looking for my vaccum issuses and even tried the either trick and still no sign of a vaccum leak. any ideas or just get a smoke test done
Old Oct 14, 2011 | 12:35 AM
jirwin's Avatar
jirwin
Either trick? What is that?
Old Oct 14, 2011 | 07:07 PM
Moyerboy's Avatar
Moyerboy
spray either around the vaccum lines and see if it revs up mind you im not much of a gas guru but a guy I work with said to try that if you cant find it so i did and nothing
Old Oct 14, 2011 | 10:39 PM
jirwin's Avatar
jirwin
Thank you. That makes sense
Old Oct 17, 2011 | 12:23 AM
Big_redneck3100's Avatar
Big_redneck3100
Ether or brake parts cleaner work great for finding a vacuum leak....just spray around the vacuum lines or fittings and when you hit the "spot" the idle will ramp up a little. That will tell you the area your leak is in. I hate dealing with vacuum leaks cause some of them are really difficult to find
RJG350
Jan 1, 2023 12:52 PM
deep101
Modular V8 (4.6L, 5.4L)
Feb 16, 2015 05:52 AM
FordTruckGirl77
Apr 16, 2009 04:11 PM
codiesvenus
General Automotive Discussion
Dec 2, 2006 05:16 AM
fordextreme
Jan 29, 2002 06:13 PM
