My scangauge II shows absolutely no codes on my truck. The SES is constantly on as I unplugged the ICP to see if my rough running cleared. The scanner says no codes and no pending codes, but when I force clear, the light blinks for a second so I know the thing is communicating with the PCM... will the scangauge II not read codes on a 7.3? The website said it would, and that's why I tossed up the cash for it.
I haven't tried to pull codes with mine, but I know there are a few different settings for how it pulls codes. You may want to try playing with the DTC settings.
I really like mine so far. More gauges then I would have room for and all seem dead on. The 7.3 will support the fast update rate.
Any luck with this yet?? I put in the Scangauge II last month; I really like it!!! I programmed some of the 7.3 X Gauge functions (pretty easy to do..) and it works like a charm!! I have had the P1211 Code pop up a couple times... pretty sure it's tuner related.... but I couldn't find anything in the manual reagarding settings to pull codes; only showing pending codes and force clearing...
