Weird choke setup help?
Old Oct 3, 2011 | 08:12 PM
tbear853's Avatar
tbear853
Originally Posted by mktsc
I might just bend up a tube like you described. Where does that vacuum line attach?
-MK
No line, there's a small piston in there is there not? It's a vacume break, and in operation it creats just enough pull to draw through the tube.
Or am I recalling a different carb?
Anyways ......
When wiring electric chokes, I went to the alternator so it only works when engine is actually running, not when accessory is on, not when key is simply on ... but only when the alternator is putting out.
Originally Posted by Tim C
Factory electric chokes are powered from the sta terminal on the alternator back.
That has a strange ring of familiarity about it!
Old Oct 4, 2011 | 06:12 AM
mktsc's Avatar
mktsc
Don't you want the choke operative before the engine fires? Or does the choke snap shut when you pump the gas before starting...
Mine's never worked, so I'm not entirely sure what the order of operation should be.
Thanks again for the help.
-MK
Old Oct 4, 2011 | 08:14 AM
Tim C's Avatar
Tim C
It will shut when you pump the gas before starting. The electric current or hot air depending on type of choke is what opens it.
Old Oct 4, 2011 | 08:41 AM
mktsc's Avatar
mktsc
Gotcha thanks.
Old Oct 4, 2011 | 08:54 AM
78Ranger400's Avatar
78Ranger400
I know this is probably too late...but I had the same issue with 79' 400M. I installed a manual choke in about 20 minutes. It was cheap, easy to install, and now I know where the choke position is all the time. Works great, I love it!!!
Old Oct 4, 2011 | 08:58 AM
mktsc's Avatar
mktsc
I installed a manual choke about 6mos ago, and was really not pleased with the kit I got. It consisted of ****ty quality parts, and the actuation of the choke was inconsisent. I couldn't get it adjusted to where it opened and closed smootly. When I wanted to open the choke all the way after the truck warmed up, I'd have to yank the **** all the way out and slam it back in. Probably has to do with the flex in the line going around corners, but I could never get mine adjusted where I wanted it. It was a quick and dirty solution, but now that I've got the carb out and apart and the weather isn't too bad, I'd like to fix it right.
Worse comes to worse and I'll try and work with the manual choke some more if the electric one doesnt work.
-MK
Old Oct 4, 2011 | 09:17 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
For your new electric choke it should tell you what to use for power source. Old factory electrics came off the stator of alt/reg and was a lower voltage,7-8v. New carbs such as Holley and Edelbrock specify full switched 12v. The original "stovepipe" choke was called that for a reason. Just like a wood burning stove, when hot air rises, it pulls air in at the bottom. The insulated tube running to choke was connected to manifold as mentioned with a filter material inside the cast chamber(usually clogged), drawing air in thru a second tube in the bottom. Most long gone. In front of the choke housing was a plate to restrict air flow crossing the choke housing preventing it from cooling too much and reactivating choke. Just plain old school technology. All suggestions mentioned will work.
Old Oct 4, 2011 | 09:22 AM
mktsc's Avatar
mktsc
So if I convert to electric choke, should I put a cap on the threded port for the choke stove tube?
-MK
Old Oct 4, 2011 | 09:35 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Should have no effect if a true electric choke. Get it working and then cap it off to see if it makes any diff. May keep dust and crap out of choke assembly.
Old Oct 4, 2011 | 09:43 AM
mktsc's Avatar
mktsc
Cool. Didin't know whether or not the air getting in there would cool the bi-metal spring and effectively cause it to operate differently.
Probably not an issue...
Old Oct 4, 2011 | 07:33 PM
mktsc's Avatar
mktsc
So I was reading through the choke setup portion of the rebuild instructions, and it talks about re-installing your choke pull-off. I don't have a choke pull-off. Forgive my ignorance, but will my electric choke function properly without a pull-off?
Thanks again guys,
-MK
Old Oct 4, 2011 | 07:58 PM
Tim C's Avatar
Tim C
It may be internal to the choke housing. Install the electric choke, let it close fully, crank the engine then immediately look and see if the choke has opened a little. If it has then you have an internal pull off.
sparkyj
Apr 26, 2012 09:24 AM
kjmdrumz3
26
Oct 29, 2008 06:51 PM
mudder460
Sep 1, 2007 08:20 PM
gsx
Jan 27, 2003 08:24 PM
supercab4x4
Sep 11, 2002 04:17 PM
