Vin decode please
Old Sep 29, 2011 | 10:56 PM
John - NNY's Avatar
John - NNY
Vin decode please
Just picked up an old and tired 1949 F-1. Glove box plate reads
97HC 336187
9HC
The truck currently has a V8 flathead and four speed (one ton?) gearbox. Pictures comming soon.
John
NNY
Old Sep 29, 2011 | 11:54 PM
51PanelMan's Avatar
51PanelMan
9 - 1949 or 1950 (depends on production sequence number)
7H - 6 cyl
C - 1/2 ton
336187 - production number
Looks to have a high production sequence number. It's likely a 50.
Does the Data tag on the firewall and/or stamping on the frame match the glove box plate?
Old Sep 30, 2011 | 12:01 AM
52 Merc's Avatar
52 Merc
Plates and tags are often changed, albeit illegally, when papers are missing. Do you have registration papers or a title for the truck? Does the numbers on your papers match the tag? Have you looked for the numbers on your frame (the legal vin) to see if they match? That vin decodes to a 49/50 226 6 cylinder F-1 truck. As mentioned, with a consecutive unit number that high, the tag is most likely a from a 1950.
Old Sep 30, 2011 | 12:33 AM
mtflat's Avatar
mtflat
Your half-ton could have a 4 spd as original equip.
Old Sep 30, 2011 | 08:14 AM
John - NNY's Avatar
John - NNY
It looks like the cross member at the back of the transmission has been hacked to get it to fit. It likely got the flathead V8 about the same time.
John
NNY
Shermie3570
Jul 25, 2018 05:57 PM
Michael.Smith928
Mar 18, 2017 02:55 PM
colson327
15
Feb 22, 2014 05:57 PM
1956f100
Oct 24, 2003 05:39 PM
