brake fluid leaking
Old Sep 29, 2011 | 08:24 PM
minkbigbird's Avatar
minkbigbird
brake fluid leaking
Hi all. I need help, I have a leaking wheel cylinder on the front of my 64 f600. the cause has just about sent me mad,I have spent more money on this truck than the national debt but it still wants to fight me. the whole brake system has been rebuilt, the wheel clyinders have been stainless sleaved new rubbers but still it leaks down the inside of the backing plate when parked overnight. the only thing that does not look right is the push rod from the brake shoe does not enter the wheel cylinder in a straight line, it is angled up slightly is this correct?could this push the piston of square in the wheel cylinder? while writing this I had a thought could the leak come from between the sleave and the body of the wheel cylinder? any help would sure be appreciated. thanks Brian.
Old Sep 29, 2011 | 09:49 PM
fivestarmmd's Avatar
fivestarmmd
I went the other way and bit the bullit and put new wheel cyl,2per wheel on a 64 F700 and had no problem other than haveing to replace booster. Nice thing it had lifetime warrenty on it.
Old Sep 29, 2011 | 09:51 PM
OldHarley's Avatar
OldHarley
Push rod if too severe an angle, maybe.
Could it possibly be the bleeder valve is not seating properly and that is the leak you see? I have never had a wheel cylinder sleeved, but I could see how a bleeder valve or seat might be damaged when the machine work for the sleeve was done. If so, the leak would be exactly in the location you described.
Old Sep 30, 2011 | 12:15 AM
Jetcopterpilot's Avatar
Jetcopterpilot
Old Harley I have to go with you on this one.. I had my left front bleeding down like that, and I replaced the bleeder... problem solved! It was leaking out under heavy breaking,and then would drizzle down the plate... so it was sporadic!
Old Sep 30, 2011 | 02:41 AM
minkbigbird
Brake fluid leaking
G'Day again. thanks for taking the time to reply, after spending most of the day the leak has been found Its coming from between the sleeve and the body of the wheel cylinder. but as always a new problem may have have been found the part number on the wheel cylinder on the truck is C1TT can't read the rest of the casting numbers and in my Australian parts catalog it shows C4TZ2062 B for the L.H. AND C4TZ2061 B for the R.H.side, could this be the reason the rod from the shoe into the cylinder is not a straight line. the cylinder is a single end and 1-1/16" dia.any thoughts? Brian.
Old Sep 30, 2011 | 02:55 AM
Jetcopterpilot
Bill Aka NumbersDummy is the guy you need to get info from.. He can probably give you the best info on the original parts for that Model,, I doubt the pickup Cylinders would work, but I could be wrong. Bill could at least clue you in to the correct part number, and who might have them. Or maybe at least give you a number to Cross reference..
Old Sep 30, 2011 | 03:09 AM
Jetcopterpilot
Is it 1-1/16" or is it 1-1/8" bore ? The pick up wheel cylinders are pretty much all 1-1/8" for that period, as far as I can find!
Old Sep 30, 2011 | 02:12 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by minkbigbird
After spending most of the day, the leak has been found. It's coming from between the sleeve and the body of the wheel cylinder.
But as always a new problem may have have been found, the part number on the wheel cylinder on the truck is C1TT can't read the rest of the casting numbers.
After 1956, numbers marked on parts are ID engineering or casting numbers, not part numbers!
My Australian parts catalog it shows C4TZ-2062-B for the L.H. and C4TZ-2061-B for the R.H.
1964/67 F600 with 14" x 2 1/2" Front Hydraulic Brakes
C4TZ-2061-B .. Right Front Wheel Cylinder - 1 1/16" / Obsolete (10)
C4TZ-2062-B .. Left Front Wheel Cylinder - 1 1/16" / Obsolete (20)
Dunno why your parts catalog shows the sides to be reversed. Maybe it's because y'all drive on the wrong side of the road.
1964/67 F600 with 15" x 3" Front Hydraulic Brakes
C4TZ-2061-D .. Right Front Wheel Cylinder - 1 1/8" / Obsolete (3)
C4TZ-2062-D .. Left Front Brake Cylinder - 1 1/8" / Obsolete (9)
( ) = Quantity available NOS from US Ford Dealers/obsolete parts vendors. I'll list the sources if you're interested.
Old Sep 30, 2011 | 07:06 PM
minkbigbird
to Number Dummy. your right, I must have hit my head under the truck or am dyslectic. Iam waiting for a quote from greens as they have them in stock.still concerned about the entry angle of the push rod. Brian.
Old Sep 30, 2011 | 09:44 PM
OldHarley's Avatar
OldHarley
Somebody musta changed their post cuz these match.
Old Oct 1, 2011 | 02:31 AM
NumberDummy
Not originally they didn't, I quoted the OP's #5 post when I responded to it. See post 8.
obscurity
15
Jun 2, 2013 03:23 PM
Htownsvenom
1978 - 1996 Big Bronco
Apr 7, 2012 02:25 PM
90Ford250
Apr 10, 2007 02:18 AM
fattmann
Nov 28, 2006 10:20 AM
BarnacleBob
Nov 11, 2006 01:22 AM
